Passive Check for a Windows File - Log Parsing
Re: Passive Check for a Windows File - Log Parsing
This was a bug that was present for about a week, that has been resolved in the new download of the component.
That said, looking at the output you have, I can say that it looks to be install correctly. the error you see is just a final test which hadn't been updated when we converted some components to perl.
ecarrasq
Post by ecarrasq »
I'm receiving
NO REQUEST HANDLER
When I try to install the NRDS Agent via the NRDS Config Manager. What could I be missing?
Where are you seeing this?
ecarrasq
Post by ecarrasq »
Sorry, I should have included more info.
I get the
NO REQUEST HANDLER
when I enter the install URL into the IE web browser (runnning IE as Administrator) of the server I am trying to monitor. I obtained the URL from the "NRDS Config Manager" under "Client install instructions. The link looks something like this:
***http://nagiosserver/nrdp/?cmd=nrdsgetcl ... ame=server**** (the "server" is the server I am trying to monitor)
I have a feeling you have an old version of NRDS.
Lets download the new component and install it via Admin -> Manage components
http://assets.nagios.com/downloads/nrdp ... anager.zip
And run the following on the Nagios XI server
cd /tmp
wget http://assets.nagios.com/downloads/nrdp/nrds.tar.gz
tar xzf nrds.tar.gz
cd nrds
./installnrdsserver
Then if you still have the same issue, lets post the output from the following after trying to download the NRDS installer
tail /var/log/httpd/error_log
