PostgreSQL install failure - Please help
gshergill
Re: PostgreSQL install failure - Please help
Post by gshergill »
Hi yancy,
By "starting the service again" you mean attempt the installation again?
Sorry am a bit confused don't want to mess anything up.
Kind Regards,
gshergill
yancy
Post by yancy »
gshergill,
Yes, please test running the Nagios installation again.
Regards,
-Yancy
gshergill
Post by gshergill »
Hi yancy,
If you meant to run the install command again,
./fullinstall
I tried that and still the same error.
Restored to before my first attempt at installation (so a fresh CentOS system) and ran the commands;
restorecon /etc/nsswitch.conf
./fullinstall
That didn't work either.
No luck as of yet unfortunately.
Kind Regards,
gshergill
Can you run the following to see what the problem might be with postgresql
tail -f /var/lib/pgsql/pgstartup.log
gshergill
Post by gshergill »
Hi scottwilkerson,
The following is the command and the output;
FATAL:  could not create any TCP/IP sockets
LOG:  could not translate host name "localhost", service "5432" to address: Name or service not known
WARNING:  could not create listen socket for "localhost"
The /etc/hosts file has the following;
cat /etc/hosts
127.0.0.1		nagiosxi.<domain>   nagiosxi
::1		localhost6.localdomain6   localhost6
The 127.0.0.1 line I edited, the 2nd line was already there.
Hope this helps.
Thank you.
Kind Regards,
gshergill
You must have "localhost" on the line that starts with 127.0.0.1. For example you should have something like this:
127.0.0.1               localhost.localdomain localhost
Hope this helps.
yancy
Post by yancy »
gshergill,
If your still having issues, also check your selinux status
 sestatus
if selinux is enabled, try disabling it to test.
Regards,
-Yancy
gshergill
Post by gshergill »
Hi guys,
Thanks lmiltchev, changing that line worked great.
The reason I changed it was to stop the error;
httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1 for ServerName
didn't realise it would effect the PostgreSQL installation.
Just wondering but how do I stop that from occurring? I use to get the same on other VM's with Apache2, changing 127.0.0.1 normally stopped it.
Hi yancy, the following is the result of the code;
sestatus
SELinux status:                 enabled
SELinuxfs mount:                /selinux
Current mode:                   permissive
Mode from config file:          disabled
Policy version:                 24
Policy from config file:        targeted
Thanks again for the support.
Kind Regards,
gshergill
