Thanks for the response.
The following is the output from netstat on Nagios XI machine;
[root@nagiosxi etc]# netstat -l -n|grep 5667
tcp 0 0 :::5667 :::* LISTEN Code: Select all
root@muninnagios:~# telnet 192.168.3.121 5667
Trying 192.168.3.121...
telnet: Unable to connect to remote host: No route to host/etc/xinetd.d/nsca
Where I have the following;
# description: NSCA (Nagios Service Check Acceptor)
service nsca
flags = REUSE
type = UNLISTED
port = 5667
socket_type = stream
wait = no
server = /usr/sbin/nsca
server_args = -c /usr/local/nagios/etc/nsca.cfg --inetd
user = nagios
group = nagios
log_on_failure += USERID
only_from = 192.168.3.121
}Using the command below you can install a nsca.cfg file (/etc/nsac.cfg), but once again it uses Nagios references in that file and changed them to the same as the Nagios XI machine still leads to the above telnet error.
aptitude install nscaThank you.
Kind Regards,
gshergill
