STATE= RSZDT
Re: STATE= RSZDT
Post by slansing »
If you run the command from the Nagios server's terminal do you still get the same result?
/usr/local/nagios/libexec/check_nrpe -H Place.Your.Localhost's Address.Here -t 30 -c check_procs -a '-w 150 -c 500'
