Problem Checking Mail
Re: Problem Checking Mail
Is it working now after you made the change?
benningtonr
Post by benningtonr »
No, same thing
CGraham
Post by CGraham »
Can you post the command you're calling?
If your smtp gateway will take mail on port 25 try it with the "-p 25" switch.
EDIT: better yet, add the "--notls" switch...
Thanks CGraham
