Upgrade to Nagios 2024R1.1.1 fails with SQL root password issue
Psihawk
Re: Upgrade to Nagios 2024R1.1.1 fails with SQL root password issue
Post by Psihawk »
There is no entry in that file for dbmaint_nagiosxi
Also this is how Nagios shows it
KarenJ
Post by KarenJ »
I'm having the same issue. Following.
bbahn
Post by bbahn »
If there is no password listed under dbmaint_nagiosxi in xi-sys.cfg and you can log into your mysql database, you can either take the existing mysql password for the dbmaint_nagiosxi user and set that in xi-sys.cfg or you can change the dbmaint_nagiosxi user's password to match whatever you put in xi-sys.cfg.
Psihawk
Post by Psihawk »
bbahn wrote: Fri May 10, 2024 11:26 am If there is no password listed under dbmaint_nagiosxi in xi-sys.cfg and you can log into your mysql database, you can either take the existing mysql password for the dbmaint_nagiosxi user and set that in xi-sys.cfg or you can change the dbmaint_nagiosxi user's password to match whatever you put in xi-sys.cfg.
How do we get that if we can login to the mysql box? Is there a command we can use to extract or find it?
Post Reply
