multiple error on nagioslogserver
jmichaelson
Re: multiple error on nagioslogserver
Post by jmichaelson »
camieg wrote: Wed Aug 21, 2024 4:43 am
in both cases I do not see the correct token sent as payload
Are you seeing any token being sent along with the request?
-Jason
camieg
Post by camieg »
Hello all,
after configuring SSL/TLS for the WEB interface the menus are no longer in error and the TOKEN is valid, I can now restart logstash or elasticsearch from the web interface.
All my worries are solved except sending email via an authenticated SMTP server
camieg
Post by camieg »
Hello all,
jmichaelson
Do you have more information about the SMTP Error? Just curious, are the port settings correct for the SSL/TLS, since that's the most obvious problem?
-Jason
Post Reply
