Nagios upgrade support
lrnnetops
Re: Nagios upgrade support
Post by lrnnetops »
What Red Hat 8 version is compatible for migrating Nagios from 5.8.7 to the latest version? What upgrade methods should be followed? Is it necessary to first install Nagios 5.8.7 on a new server before upgrading to 5.10 and then the latest version?
lrnnetops
Post by lrnnetops »
Hi all,
I've successfully upgraded the OS to RHEL 8. However, after migrating, the Nagios login page displays a blank page. I've restored files from the old node, but the page still isn't loading correctly.
jmichaelson
Post by jmichaelson »
Can you post the last few lines of /var/log/php-fpm/www-error.log?
-Jason
lrnnetops
Post by lrnnetops »
After migrating from RHEL 7.9 to RHEL 8.10 using an AMI of the older system, some packages were lost. This results in a blank Nagios page with 304 status codes in the access logs. I'm attempting to upgrade Nagios from 5.8.7 to 5.10, as this is a required intermediate step before upgrading to the latest version.
lrnnetops
Post by lrnnetops »
jmichaelson wrote: Thu Mar 20, 2025 1:45 pm Can you post the last few lines of /var/log/php-fpm/www-error.log?
[23-Mar-2025 03:36:01] NOTICE: error log file re-opened
lrnnetops
Post by lrnnetops »
Hi team,
Any updated on it.
Post Reply
