RESOLVED: New install of Nagios XI - What next for Windows Monitoring
LACMAIS
Re: New install of Nagios XI - What next for Windows Monitoring
Post by LACMAIS »
lgute wrote: Thu Mar 13, 2025 4:00 pm Hi @LACMAIS,
Do you have any special characters in your NCPA Community string/Token?
Yes, I do. I will change to numbers and letters and edit the .cfg file and restart the agent and see if that clears up the issues... or do I need to uninstall and re-install?
LACMAIS
Post by LACMAIS »
LACMAIS wrote: Thu Mar 13, 2025 5:26 pm
Token changed to just uppercase, lowercase, and numbers on both the host (agent restarted) and the server and while the host still shows as active, all other things being monitored are still showing as critical and with the error code 127.
lgute
Post by lgute »
Hi @LACMAIS,
Have you tried running check_ncpa.py, from a few posts back, with the new token?
If that works, you will need to update the Service checks with the new NCPA token.
-Laura
LACMAIS
Post by LACMAIS »
lgute wrote: Fri Mar 14, 2025 1:59 pm Hi @LACMAIS,
I tried with the new token and this time I get:
CRITICAL: Incorrect credentials given.
I try the new token with the website and it allows me in. Is there a token length maximum for the CLI? Current token length is 16 characters
LACMAIS
Post by LACMAIS »
I reduced the length of the token to 12 characters and again, it works with the agent's website, but not in the CLI - Same error as this last time, Incorrect credentials given.
LACMAIS
Post by LACMAIS »
I deleted the services and the host and recreated with the new shorter token, and now things seem to be working.
Thank you all for your help and guidance.
lgute
Post by lgute »
Hi @LACMAIS,
Thank you for letting us know that you got things working. I am going to lock this topic and mark it resolved.
In the near future, XI will handle special characters in NCPA tokens.
-Laura
