Hundreds of Active Check result files in /tmp
jbennett
Re: Hundreds of Active Check result files in /tmp
Post by jbennett »
Please find attached & thank you for the assistance!
Out of curiosity, since the reboot has the "Monitoring Performance" normalized?
Also, what type of load is the system running at? How many CPU's does the machine have?
jbennett
Post by jbennett »
Here's the latest monitoring performance:
Service Check Execution Time:	0.00 / 16.52 / 2.438 sec
Service Check Latency:	0.00 / 9036.62 / 1313.110 sec
Host Check Execution Time:	0.00 / 11.44 / 1.480 sec
Host Check Latency:	0.00 / 7059.46 / 1916.317 sec
# Active Host / Service Checks:	3008 / 5613
# Passive Host / Service Checks:	0 / 1
I have just deactivated 741 hosts; but, added in about 100 for a new area that is opening within the company.
I still have some of the deactivated hosts showing up as down though. Even after stopping/starting Nagios.
This machine is a VM running on 8 CPUs & 16GB memory.
[root@nagiosxivm ~]# top
top - 15:52:19 up 55 min,  1 user,  load average: 6.80, 10.51, 10.44
Tasks: 248 total,   2 running, 245 sleeping,   0 stopped,   1 zombie
Cpu(s):  0.6%us,  0.6%sy,  0.0%ni, 65.4%id, 32.6%wa,  0.1%hi,  0.6%si,  0.0%st
Mem:  15463692k total,  1486024k used, 13977668k free,   121540k buffers
Swap:   262136k total,        0k used,   262136k free,   679180k cached
[root@nagiosxivm ~]# mpstat -P ALL
Linux 2.6.32-220.4.1.el6.i686 (nagiosxivm)      10/08/2012      _i686_  (8 CPU)
03:54:08 PM  CPU    %usr   %nice    %sys %iowait    %irq   %soft  %steal  %guest   %idle
03:54:08 PM  all    5.43    0.00    6.06   14.90    0.23    1.36    0.00    0.00   72.02
03:54:08 PM    0    3.62    0.00    4.70   16.94    1.20    1.66    0.00    0.00   71.89
03:54:08 PM    1    6.69    0.00    6.97   12.49    0.10    0.73    0.00    0.00   73.03
03:54:08 PM    2    4.43    0.00    5.26   17.60    0.08    2.05    0.00    0.00   70.57
03:54:08 PM    3    6.70    0.00    7.15   12.96    0.11    0.60    0.00    0.00   72.48
03:54:08 PM    4    4.36    0.00    5.53   16.94    0.08    2.31    0.00    0.00   70.78
03:54:08 PM    5    6.93    0.00    7.06   13.08    0.08    0.52    0.00    0.00   72.34
03:54:08 PM    6    4.36    0.00    5.36   16.99    0.07    2.34    0.00    0.00   70.89
03:54:08 PM    7    6.43    0.00    6.53   12.02    0.10    0.62    0.00    0.00   74.30
jbennett
Post by jbennett »
I just went through and de-activated quite a few more hosts, for a total of around 1500 deactivated. I applied the change as well.
However, my active host / service checks is still showing the same count:
I'm also still seeing some of these hosts still showing up.
I am wondering if running a database repair might help?
Can you post the output of
ps -ef|grep bin/nagios
jbennett
Post by jbennett »
I am currently running a backup on the same machine, but here are the results:
[root@nagiosxivm ~]# ps -ef|grep bin/nagios
nagios    9147     1  0 10:21 ?        00:00:42 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   17667  9147  0 11:36 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root     17670 17651  2 11:36 pts/1    00:00:00 grep bin/nagios
jbennett
Post by jbennett »
I just ran the repairing the DB script per this document (http://assets.nagios.com/downloads/nagi ... tabase.pdf) and have the same results.
Post by slansing »
Did the repair run into any errors that you could see? I know it scrolls quite fast sometimes but sometimes it provides a good bread crumb trail to the root issue.
jbennett
Post by jbennett »
I just scrolled up as far as I could through the process, and I didn't see any errors.
I was able to go up to:
- recovering (with sort) MyISAM-table 'nagios_logentries.MYI'
Data records: 265875
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
I did not watch the process closely though. Should I try it once more and watch it this time around?
Post by slansing »
It certainly would not hurt to run it again.
I would also run the following whilst running the repair if possible:
tail -f /var/log/mysqld.log
