next question. on both systems, look at /usr/local/nagioslogserver/opensearch/config/opensearch.yml
what is in the network.publish_host and discovery.seed_hosts entries?
Nagios Log Server - Waiting For Database Startup When Adding a 2024R2 Instance to a Cluster
- jmichaelson
Re: Nagios Log Server - Waiting For Database Startup When Adding a 2024R2 Instance to a Cluster
-Jason
-Jason
The NagiosLogServer 2026R1 corrected the Waiting for Database Startup problem. I was able to successfully install it on the primary and secondary instance. The web GUI properly launches for both the primary and secondary instance. And the primary node correctly shows two instances in the cluster. I had no success with any of the NagiosLogServer 2024R2 versions.
