SNMP walk job selecting OIDs
jsimon
Re: SNMP walk job selecting OIDs
Post by jsimon »
Hi Dave,
I was able to isolate the cause of the issue with the help of your data. It looks like the issue is actually that your device returns multi-component indices for its OIDs, which we did not account for in the filtering the wizard performs. I was able to fix this with a very small change, just adding a character to the regex whitelist for OID values, which will be going into a future release of Nagios XI. In the meantime, you can fix this for your own XI server by running the following command in a terminal session with your XI server:
As a note, it's generally a good idea to back up the file being changed, just in case anything goes wrong.
sed -i "s|\[a-zA-Z0-9_-\]|\[a-zA-Z0-9._-\]|" /usr/local/nagiosxi/html/includes/configwizards/snmpwalk/snmpwalk.inc.php
Thank you for your patience! Let us know if you have any questions about this or run into any issues with it.
davemulv1
Post by davemulv1 »
So following this fix I ran the same job and it does show a selection table of 261 OIDs but it gives this boatload of errors first:
warning Invalid warning numeric range for OID (jnxOperatingContentsIndex.1.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingContentsIndex.1.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingContentsIndex.2.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingContentsIndex.2.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingContentsIndex.2.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingContentsIndex.2.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingContentsIndex.4.1.1.1)
warning Invalid critical numeric range for OID (jnxOperatingContentsIndex.4.1.1.1)
warning Invalid warning numeric range for OID (jnxOperatingContentsIndex.4.1.2.1)
warning Invalid critical numeric range for OID (jnxOperatingContentsIndex.4.1.2.1)
warning Invalid warning numeric range for OID (jnxOperatingContentsIndex.7.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingContentsIndex.7.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingContentsIndex.8.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingContentsIndex.8.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingContentsIndex.8.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingContentsIndex.8.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingContentsIndex.9.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingContentsIndex.9.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingL1Index.1.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingL1Index.1.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingL1Index.2.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingL1Index.2.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingL1Index.2.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingL1Index.2.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingL1Index.4.1.1.1)
warning Invalid critical numeric range for OID (jnxOperatingL1Index.4.1.1.1)
warning Invalid warning numeric range for OID (jnxOperatingL1Index.4.1.2.1)
warning Invalid critical numeric range for OID (jnxOperatingL1Index.4.1.2.1)
warning Invalid warning numeric range for OID (jnxOperatingL1Index.7.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingL1Index.7.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingL1Index.8.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingL1Index.8.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingL1Index.8.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingL1Index.8.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingL1Index.9.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingL1Index.9.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingL2Index.1.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingL2Index.1.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingL2Index.2.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingL2Index.2.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingL2Index.2.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingL2Index.2.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingL2Index.4.1.1.1)
warning Invalid critical numeric range for OID (jnxOperatingL2Index.4.1.1.1)
warning Invalid warning numeric range for OID (jnxOperatingL2Index.4.1.2.1)
warning Invalid critical numeric range for OID (jnxOperatingL2Index.4.1.2.1)
warning Invalid warning numeric range for OID (jnxOperatingL2Index.7.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingL2Index.7.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingL2Index.8.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingL2Index.8.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingL2Index.8.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingL2Index.8.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingL2Index.9.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingL2Index.9.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingL3Index.1.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingL3Index.1.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingL3Index.2.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingL3Index.2.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingL3Index.2.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingL3Index.2.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingL3Index.4.1.1.1)
warning Invalid critical numeric range for OID (jnxOperatingL3Index.4.1.1.1)
warning Invalid warning numeric range for OID (jnxOperatingL3Index.4.1.2.1)
warning Invalid critical numeric range for OID (jnxOperatingL3Index.4.1.2.1)
warning Invalid warning numeric range for OID (jnxOperatingL3Index.7.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingL3Index.7.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingL3Index.8.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingL3Index.8.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingL3Index.8.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingL3Index.8.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingL3Index.9.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingL3Index.9.1.0.0)
warning Threshold is empty for OID (jnxOperatingDescr.1.1.0.0)
warning Threshold is empty for OID (jnxOperatingDescr.2.1.1.0)
warning Threshold is empty for OID (jnxOperatingDescr.2.1.2.0)
warning Threshold is empty for OID (jnxOperatingDescr.4.1.1.1)
warning Threshold is empty for OID (jnxOperatingDescr.4.1.2.1)
warning Threshold is empty for OID (jnxOperatingDescr.7.1.0.0)
warning Threshold is empty for OID (jnxOperatingDescr.8.1.1.0)
warning Threshold is empty for OID (jnxOperatingDescr.8.1.2.0)
warning Threshold is empty for OID (jnxOperatingDescr.9.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingState.1.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingState.1.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingState.2.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingState.2.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingState.2.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingState.2.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingState.4.1.1.1)
warning Invalid critical numeric range for OID (jnxOperatingState.4.1.1.1)
warning Invalid warning numeric range for OID (jnxOperatingState.4.1.2.1)
warning Invalid critical numeric range for OID (jnxOperatingState.4.1.2.1)
warning Invalid warning numeric range for OID (jnxOperatingState.7.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingState.7.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingState.8.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingState.8.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingState.8.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingState.8.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingState.9.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingState.9.1.0.0)
warning Threshold is empty for OID (jnxOperatingTemp.1.1.0.0)
warning Threshold is empty for OID (jnxOperatingTemp.2.1.1.0)
warning Threshold is empty for OID (jnxOperatingTemp.2.1.2.0)
warning Threshold is empty for OID (jnxOperatingTemp.4.1.1.1)
warning Threshold is empty for OID (jnxOperatingTemp.4.1.2.1)
warning Threshold is empty for OID (jnxOperatingTemp.7.1.0.0)
warning Threshold is empty for OID (jnxOperatingTemp.8.1.1.0)
warning Threshold is empty for OID (jnxOperatingTemp.8.1.2.0)
warning Threshold is empty for OID (jnxOperatingTemp.9.1.0.0)
warning Threshold is empty for OID (jnxOperatingCPU.1.1.0.0)
warning Threshold is empty for OID (jnxOperatingCPU.2.1.1.0)
warning Threshold is empty for OID (jnxOperatingCPU.2.1.2.0)
warning Threshold is empty for OID (jnxOperatingCPU.4.1.1.1)
warning Threshold is empty for OID (jnxOperatingCPU.4.1.2.1)
warning Threshold is empty for OID (jnxOperatingCPU.7.1.0.0)
warning Threshold is empty for OID (jnxOperatingCPU.8.1.1.0)
warning Threshold is empty for OID (jnxOperatingCPU.8.1.2.0)
warning Threshold is empty for OID (jnxOperatingCPU.9.1.0.0)
warning Threshold is empty for OID (jnxOperatingISR.1.1.0.0)
warning Threshold is empty for OID (jnxOperatingISR.2.1.1.0)
warning Threshold is empty for OID (jnxOperatingISR.2.1.2.0)
warning Threshold is empty for OID (jnxOperatingISR.4.1.1.1)
warning Threshold is empty for OID (jnxOperatingISR.4.1.2.1)
warning Threshold is empty for OID (jnxOperatingISR.7.1.0.0)
warning Threshold is empty for OID (jnxOperatingISR.8.1.1.0)
warning Threshold is empty for OID (jnxOperatingISR.8.1.2.0)
warning Threshold is empty for OID (jnxOperatingISR.9.1.0.0)
warning Threshold is empty for OID (jnxOperatingDRAMSize.1.1.0.0)
warning Threshold is empty for OID (jnxOperatingDRAMSize.2.1.1.0)
warning Threshold is empty for OID (jnxOperatingDRAMSize.2.1.2.0)
warning Threshold is empty for OID (jnxOperatingDRAMSize.4.1.1.1)
warning Threshold is empty for OID (jnxOperatingDRAMSize.4.1.2.1)
warning Threshold is empty for OID (jnxOperatingDRAMSize.7.1.0.0)
warning Threshold is empty for OID (jnxOperatingDRAMSize.8.1.1.0)
warning Threshold is empty for OID (jnxOperatingDRAMSize.8.1.2.0)
warning Threshold is empty for OID (jnxOperatingDRAMSize.9.1.0.0)
warning Threshold is empty for OID (jnxOperatingBuffer.1.1.0.0)
warning Threshold is empty for OID (jnxOperatingBuffer.2.1.1.0)
warning Threshold is empty for OID (jnxOperatingBuffer.2.1.2.0)
warning Threshold is empty for OID (jnxOperatingBuffer.4.1.1.1)
warning Threshold is empty for OID (jnxOperatingBuffer.4.1.2.1)
warning Threshold is empty for OID (jnxOperatingBuffer.7.1.0.0)
warning Threshold is empty for OID (jnxOperatingBuffer.8.1.1.0)
warning Threshold is empty for OID (jnxOperatingBuffer.8.1.2.0)
warning Threshold is empty for OID (jnxOperatingBuffer.9.1.0.0)
warning Threshold is empty for OID (jnxOperatingHeap.1.1.0.0)
warning Threshold is empty for OID (jnxOperatingHeap.2.1.1.0)
warning Threshold is empty for OID (jnxOperatingHeap.2.1.2.0)
warning Threshold is empty for OID (jnxOperatingHeap.4.1.1.1)
warning Threshold is empty for OID (jnxOperatingHeap.4.1.2.1)
warning Threshold is empty for OID (jnxOperatingHeap.7.1.0.0)
warning Threshold is empty for OID (jnxOperatingHeap.8.1.1.0)
warning Threshold is empty for OID (jnxOperatingHeap.8.1.2.0)
warning Threshold is empty for OID (jnxOperatingHeap.9.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingUpTime.1.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingUpTime.1.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingUpTime.2.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingUpTime.2.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingUpTime.2.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingUpTime.2.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingUpTime.4.1.1.1)
warning Invalid critical numeric range for OID (jnxOperatingUpTime.4.1.1.1)
warning Invalid warning numeric range for OID (jnxOperatingUpTime.4.1.2.1)
warning Invalid critical numeric range for OID (jnxOperatingUpTime.4.1.2.1)
warning Invalid warning numeric range for OID (jnxOperatingUpTime.7.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingUpTime.7.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingUpTime.8.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingUpTime.8.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingUpTime.8.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingUpTime.8.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingUpTime.9.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingUpTime.9.1.0.0)
warning Threshold is empty for OID (jnxOperatingLastRestart.1.1.0.0)
warning Threshold is empty for OID (jnxOperatingLastRestart.2.1.1.0)
warning Threshold is empty for OID (jnxOperatingLastRestart.2.1.2.0)
warning Threshold is empty for OID (jnxOperatingLastRestart.4.1.1.1)
warning Threshold is empty for OID (jnxOperatingLastRestart.4.1.2.1)
warning Threshold is empty for OID (jnxOperatingLastRestart.7.1.0.0)
warning Threshold is empty for OID (jnxOperatingLastRestart.8.1.1.0)
warning Threshold is empty for OID (jnxOperatingLastRestart.8.1.2.0)
warning Threshold is empty for OID (jnxOperatingLastRestart.9.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingMemory.1.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingMemory.1.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingMemory.2.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingMemory.2.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingMemory.2.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingMemory.2.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingMemory.4.1.1.1)
warning Invalid critical numeric range for OID (jnxOperatingMemory.4.1.1.1)
warning Invalid warning numeric range for OID (jnxOperatingMemory.4.1.2.1)
warning Invalid critical numeric range for OID (jnxOperatingMemory.4.1.2.1)
warning Invalid warning numeric range for OID (jnxOperatingMemory.7.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingMemory.7.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingMemory.8.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingMemory.8.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingMemory.8.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingMemory.8.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingMemory.9.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingMemory.9.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingStateOrdered.1.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingStateOrdered.1.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingStateOrdered.2.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingStateOrdered.2.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingStateOrdered.2.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingStateOrdered.2.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingStateOrdered.4.1.1.1)
warning Invalid critical numeric range for OID (jnxOperatingStateOrdered.4.1.1.1)
warning Invalid warning numeric range for OID (jnxOperatingStateOrdered.4.1.2.1)
warning Invalid critical numeric range for OID (jnxOperatingStateOrdered.4.1.2.1)
warning Invalid warning numeric range for OID (jnxOperatingStateOrdered.7.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingStateOrdered.7.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingStateOrdered.8.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingStateOrdered.8.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingStateOrdered.8.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingStateOrdered.8.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingStateOrdered.9.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingStateOrdered.9.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingChassisId.1.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingChassisId.1.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingChassisId.2.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingChassisId.2.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingChassisId.2.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingChassisId.2.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingChassisId.4.1.1.1)
warning Invalid critical numeric range for OID (jnxOperatingChassisId.4.1.1.1)
warning Invalid warning numeric range for OID (jnxOperatingChassisId.4.1.2.1)
warning Invalid critical numeric range for OID (jnxOperatingChassisId.4.1.2.1)
warning Invalid warning numeric range for OID (jnxOperatingChassisId.7.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingChassisId.7.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingChassisId.8.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingChassisId.8.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingChassisId.8.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingChassisId.8.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingChassisId.9.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingChassisId.9.1.0.0)
warning Threshold is empty for OID (jnxOperatingChassisDescr.1.1.0.0)
warning Threshold is empty for OID (jnxOperatingChassisDescr.2.1.1.0)
warning Threshold is empty for OID (jnxOperatingChassisDescr.2.1.2.0)
warning Threshold is empty for OID (jnxOperatingChassisDescr.4.1.1.1)
warning Threshold is empty for OID (jnxOperatingChassisDescr.4.1.2.1)
warning Threshold is empty for OID (jnxOperatingChassisDescr.7.1.0.0)
warning Threshold is empty for OID (jnxOperatingChassisDescr.8.1.1.0)
warning Threshold is empty for OID (jnxOperatingChassisDescr.8.1.2.0)
warning Threshold is empty for OID (jnxOperatingChassisDescr.9.1.0.0)
warning Threshold is empty for OID (jnxOperatingRestartTime.1.1.0.0)
warning Threshold is empty for OID (jnxOperatingRestartTime.2.1.1.0)
warning Threshold is empty for OID (jnxOperatingRestartTime.2.1.2.0)
warning Threshold is empty for OID (jnxOperatingRestartTime.4.1.1.1)
warning Threshold is empty for OID (jnxOperatingRestartTime.4.1.2.1)
warning Threshold is empty for OID (jnxOperatingRestartTime.7.1.0.0)
warning Threshold is empty for OID (jnxOperatingRestartTime.8.1.1.0)
warning Threshold is empty for OID (jnxOperatingRestartTime.8.1.2.0)
warning Threshold is empty for OID (jnxOperatingRestartTime.9.1.0.0)
warning Threshold is empty for OID (jnxOperating1MinLoadAvg.1.1.0.0)
warning Threshold is empty for OID (jnxOperating1MinLoadAvg.2.1.1.0)
warning Threshold is empty for OID (jnxOperating1MinLoadAvg.2.1.2.0)
warning Threshold is empty for OID (jnxOperating1MinLoadAvg.4.1.1.1)
warning Threshold is empty for OID (jnxOperating1MinLoadAvg.4.1.2.1)
warning Threshold is empty for OID (jnxOperating1MinLoadAvg.7.1.0.0)
warning Threshold is empty for OID (jnxOperating1MinLoadAvg.8.1.1.0)
warning Threshold is empty for OID (jnxOperating1MinLoadAvg.8.1.2.0)
warning Threshold is empty for OID (jnxOperating1MinLoadAvg.9.1.0.0)
warning Threshold is empty for OID (jnxOperating5MinLoadAvg.1.1.0.0)
warning Threshold is empty for OID (jnxOperating5MinLoadAvg.2.1.1.0)
warning Threshold is empty for OID (jnxOperating5MinLoadAvg.2.1.2.0)
warning Threshold is empty for OID (jnxOperating5MinLoadAvg.4.1.1.1)
warning Threshold is empty for OID (jnxOperating5MinLoadAvg.4.1.2.1)
warning Threshold is empty for OID (jnxOperating5MinLoadAvg.7.1.0.0)
warning Threshold is empty for OID (jnxOperating5MinLoadAvg.8.1.1.0)
warning Threshold is empty for OID (jnxOperating5MinLoadAvg.8.1.2.0)
warning Threshold is empty for OID (jnxOperating5MinLoadAvg.9.1.0.0)
warning Threshold is empty for OID (jnxOperating15MinLoadAvg.1.1.0.0)
warning Threshold is empty for OID (jnxOperating15MinLoadAvg.2.1.1.0)
warning Threshold is empty for OID (jnxOperating15MinLoadAvg.2.1.2.0)
warning Threshold is empty for OID (jnxOperating15MinLoadAvg.4.1.1.1)
warning Threshold is empty for OID (jnxOperating15MinLoadAvg.4.1.2.1)
warning Threshold is empty for OID (jnxOperating15MinLoadAvg.7.1.0.0)
warning Threshold is empty for OID (jnxOperating15MinLoadAvg.8.1.1.0)
warning Threshold is empty for OID (jnxOperating15MinLoadAvg.8.1.2.0)
warning Threshold is empty for OID (jnxOperating15MinLoadAvg.9.1.0.0)
warning Threshold is empty for OID (jnxOperating1MinAvgCPU.1.1.0.0)
warning Threshold is empty for OID (jnxOperating1MinAvgCPU.2.1.1.0)
warning Threshold is empty for OID (jnxOperating1MinAvgCPU.2.1.2.0)
warning Threshold is empty for OID (jnxOperating1MinAvgCPU.4.1.1.1)
warning Threshold is empty for OID (jnxOperating1MinAvgCPU.4.1.2.1)
warning Threshold is empty for OID (jnxOperating1MinAvgCPU.7.1.0.0)
warning Threshold is empty for OID (jnxOperating1MinAvgCPU.8.1.1.0)
warning Threshold is empty for OID (jnxOperating1MinAvgCPU.8.1.2.0)
warning Threshold is empty for OID (jnxOperating1MinAvgCPU.9.1.0.0)
warning Threshold is empty for OID (jnxOperating5MinAvgCPU.1.1.0.0)
warning Threshold is empty for OID (jnxOperating5MinAvgCPU.2.1.1.0)
warning Threshold is empty for OID (jnxOperating5MinAvgCPU.2.1.2.0)
warning Threshold is empty for OID (jnxOperating5MinAvgCPU.4.1.1.1)
warning Threshold is empty for OID (jnxOperating5MinAvgCPU.4.1.2.1)
warning Threshold is empty for OID (jnxOperating5MinAvgCPU.7.1.0.0)
warning Threshold is empty for OID (jnxOperating5MinAvgCPU.8.1.1.0)
warning Threshold is empty for OID (jnxOperating5MinAvgCPU.8.1.2.0)
warning Threshold is empty for OID (jnxOperating5MinAvgCPU.9.1.0.0)
warning Threshold is empty for OID (jnxOperating15MinAvgCPU.1.1.0.0)
warning Threshold is empty for OID (jnxOperating15MinAvgCPU.2.1.1.0)
warning Threshold is empty for OID (jnxOperating15MinAvgCPU.2.1.2.0)
warning Threshold is empty for OID (jnxOperating15MinAvgCPU.4.1.1.1)
warning Threshold is empty for OID (jnxOperating15MinAvgCPU.4.1.2.1)
warning Threshold is empty for OID (jnxOperating15MinAvgCPU.7.1.0.0)
warning Threshold is empty for OID (jnxOperating15MinAvgCPU.8.1.1.0)
warning Threshold is empty for OID (jnxOperating15MinAvgCPU.8.1.2.0)
warning Threshold is empty for OID (jnxOperating15MinAvgCPU.9.1.0.0)
warning Threshold is empty for OID (jnxOperatingFRUPower.1.1.0.0)
warning Threshold is empty for OID (jnxOperatingFRUPower.2.1.1.0)
warning Threshold is empty for OID (jnxOperatingFRUPower.2.1.2.0)
warning Threshold is empty for OID (jnxOperatingFRUPower.4.1.1.1)
warning Threshold is empty for OID (jnxOperatingFRUPower.4.1.2.1)
warning Threshold is empty for OID (jnxOperatingFRUPower.7.1.0.0)
warning Threshold is empty for OID (jnxOperatingFRUPower.8.1.1.0)
warning Threshold is empty for OID (jnxOperatingFRUPower.8.1.2.0)
warning Threshold is empty for OID (jnxOperatingFRUPower.9.1.0.0)
warning Threshold is empty for OID (jnxOperatingBufferCP.1.1.0.0)
warning Threshold is empty for OID (jnxOperatingBufferCP.2.1.1.0)
warning Threshold is empty for OID (jnxOperatingBufferCP.2.1.2.0)
warning Threshold is empty for OID (jnxOperatingBufferCP.4.1.1.1)
warning Threshold is empty for OID (jnxOperatingBufferCP.4.1.2.1)
warning Threshold is empty for OID (jnxOperatingBufferCP.7.1.0.0)
warning Threshold is empty for OID (jnxOperatingBufferCP.8.1.1.0)
warning Threshold is empty for OID (jnxOperatingBufferCP.8.1.2.0)
warning Threshold is empty for OID (jnxOperatingBufferCP.9.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingMemoryCP.1.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingMemoryCP.1.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingMemoryCP.2.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingMemoryCP.2.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingMemoryCP.2.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingMemoryCP.2.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingMemoryCP.4.1.1.1)
warning Invalid critical numeric range for OID (jnxOperatingMemoryCP.4.1.1.1)
warning Invalid warning numeric range for OID (jnxOperatingMemoryCP.4.1.2.1)
warning Invalid critical numeric range for OID (jnxOperatingMemoryCP.4.1.2.1)
warning Invalid warning numeric range for OID (jnxOperatingMemoryCP.7.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingMemoryCP.7.1.0.0)
warning Invalid warning numeric range for OID (jnxOperatingMemoryCP.8.1.1.0)
warning Invalid critical numeric range for OID (jnxOperatingMemoryCP.8.1.1.0)
warning Invalid warning numeric range for OID (jnxOperatingMemoryCP.8.1.2.0)
warning Invalid critical numeric range for OID (jnxOperatingMemoryCP.8.1.2.0)
warning Invalid warning numeric range for OID (jnxOperatingMemoryCP.9.1.0.0)
warning Invalid critical numeric range for OID (jnxOperatingMemoryCP.9.1.0.0)
warning Threshold is empty for OID (jnxOperatingBufferExt.1.1.0.0)
warning Threshold is empty for OID (jnxOperatingBufferExt.2.1.1.0)
warning Threshold is empty for OID (jnxOperatingBufferExt.2.1.2.0)
warning Threshold is empty for OID (jnxOperatingBufferExt.4.1.1.1)
warning Threshold is empty for OID (jnxOperatingBufferExt.4.1.2.1)
warning Threshold is empty for OID (jnxOperatingBufferExt.7.1.0.0)
warning Threshold is empty for OID (jnxOperatingBufferExt.8.1.1.0)
warning Threshold is empty for OID (jnxOperatingBufferExt.8.1.2.0)
warning Threshold is empty for OID (jnxOperatingBufferExt.9.1.0.0)
davemulv1
Post by davemulv1 »
Also it seems the match type of numeric is not appropriate for an operating state value such as running(2). Can't set a threshold for that. But if I try changing match value to string it doesn't change the thresholds field format. Seems like I would need a match type that listed good, warning, critical values vs. a range/threshold.
Dave
jsimon
Post by jsimon »
Hmm, yep I see what you mean on the threshold field format. That should be changing but it looks like we may have a regression. Thanks for letting us know about that, I'll be looking into it today.
In the meantime it looks like the other issue you're seeing has to do with validation issues. Any MIB you have selected on the wizard will attempt to create a monitoring service for that MIB, so you'll need to enter the mandatory threshold values.
jsimon
Post by jsimon »
Dave,
I've gotten a fix implemented for the Match Type bug you identified. The issue is written up under #2495 and should be in the May changelog tagged under that number.
I don't have a concise hotfix for this issue, but you can probably work around it in the meantime by just setting up checks using what the wizard will let you do, and then modifying the check command you need to be a string with the CCM.
Post Reply
