Capacity planning reports
lafargeuser
Re: Capacity planning reports
My question remain the same. Can i pull average % monthwise report. e.g. Memory, CPU & Disk Utilization.
As I showed you above and in screenshots this is not the true function of Capacity Planning reports, though you can go back a month and extrapolate next month's capacity projections with the tool.While you can use Capacity planning for this "Extrapolating data from a month ago," this is not the direct function of the system. It is for future projections, the Graph Explorer would be something more along the lines you are looking for.
lafargeuser
Can you pls. send actual one ?
I want to see if, I can fetch these reports using Capacity Planning.
I guess I am a little confused about your question, Capacity planning report doesn't report averages over a period.
You can see the averages for a period if you look at the standard performance graph on the service detail page, but we do not have this in a report.
