Easiest way to Mass change contact group settings for Alerts
Re: Easiest way to Mass change contact group settings for Al
hmm still 284 entries with no notification time period or check time period...whats the simplest way to fix these?
Can you look at one of these items in the CCM and see if they have something set (maybe a different timeperiod that is inactive)
Is there an easy way to fix the 284 services missing this info now?
The notification period can be changed with the Bulk Modification tool.
First go to the CCM -> Time Periods
find the ID in the far right column of the period you would like to set.
Go to CCM -> Tools -> Bulk Modification tool
Change a Single Config Option
select notification
enter the ID for your time period in the Value field
select hosts / services you want it applied to.
Save
select notification
Save
Thanks this is working
