check_nt!MEMUSE showing wrong info
lafargeuser
Re: check_nt!MEMUSE showing wrong info
Post by lafargeuser »
./check_nrpe -H 172.17.98.163 -p 5666 -c CheckMEM -a MaxWarn=$ARG1$% MaxCrit=$ARG2$% ShowAll type=physical
CRITICAL: physical memory: Total: 2G - Used: 664M (32%) - Free: 1.35G (68%) > critical|'physical memory %'=32%;0;0 'physical memory'=696369152B;0;0;0;214701670433
Now i can see correct Memory. But in GUI still i can see 4095 Memory.
Memory Usage OK 02-11-2013 12:40:44 2d 0h 4m 4s 1/3 Memory usage: total:4095.14 Mb - used: 700.98 Mb (17%) - free: 3394.16 Mb (83%)
Where do i have to make changes & How. Pls. let me know. Would be reall appericate.
Post by slansing »
Did you allow the check in the UI to update when the value after it runs again? It will still show the previous value until it has ran.
lafargeuser
I did some changes in commands.cfg file but it didnt work.
Will You pls. help me with, how to allow the check in the UI to update the actual value.
Post by slansing »
For the sake of testing, try changing your command to from:
To:
ShowAll=long type=physical
lafargeuser
Slansing,
It shows me the same output.
Will you pls. help me with, which configuration file i have to make changes & what ? So that it will show correct memory.
However, it show correct memory if i use snmp monitoring.
There are 300+ server on which i am getting wrong mem info.
abrist
Red Shirt
Post by abrist »
lafargeuser wrote: Memory Usage OK 02-11-2013 12:40:44 2d 0h 4m 4s 1/3 Memory usage: total:4095.14 Mb - used: 700.98 Mb (17%) - free: 3394.16 Mb (83%)
Where do you receive this output? In XI? From the cli? ?
lafargeuser
In XI.
It show wrong mem info mean if 2 GB is exist on server it shows double pagefile + physical mem = total memory.
When i login into XI weburl under services it shows wrong info.
Where i have to make changes so that it will reflect actual mem in XI.
You posted on the Nagios Core forum... Are you using Nagios XI?
Can you post your command definition so that we can review it?
lafargeuser
command_name CheckMEM
command_line /usr/local/nagios/libexec/check_nrpe -H 172.17.98.163 -c CheckMEM
Also i tried below
command_line /usr/local/nagios/libexec/check_nrpe -H 172.17.98.163 -c CheckMEM -a MaxWarn $ARG1$% MaxCrit $ARG2$% type "physical"
abrist
Red Shirt
Post by abrist »
You need to have the proper syntax. Compare your check to this one.
command_line /usr/local/nagios/libexec/check_nrpe -H 172.17.98.163 -c CheckMEM -a MaxWarn $ARG1$% MaxCrit $ARG2$% type=physical
type=physical
