File Count Monitoring using NRPE
yancy
Re: File Count Monitoring using NRPE
Post by yancy »
MSPK,
you could do it in one command, like so:
check_winfile.exe --target "c:\windows" && check_winfile.exe --target "c:\temp"
this way, if the first check was ok, it would test the 2nd check and so on. Although it's a bit of a hack because if the both the first and the 2nd could fail and you would only know the first failed.
probably best to just use separate check definitions.
-Yancy
MSPk
Post by MSPk »
Please close this link as solved
