find process flooding my system
ytlcomm
Re: find process flooding my system
Post by ytlcomm »
For now I will remove this manually. But later, did Nagios remove this automatically? We're in the middle of integrating new hosts into our Nagios system and this will generate more backup files isn't it?
- Faiz
mguthrie
Post by mguthrie »
Nagios XI is supposed to clean up these files automatically, that's what the cleaner.php cron job normally does. I'm not entirely sure *why this occurred, because I haven't seen this particular issue before. The subscript that was failing simply runs the following command:
find /etc/nagiosql/backup -mmin +1440 -type f -exec rm -f {} \;
Which removes any config files older than one week from that directory.
ytlcomm
Post by ytlcomm »
We will proceed to manually remove all the file and closely monitor it's condition after this. Thanks.
mguthrie
Post by mguthrie »
Ok, let us know if this issue shows up again, thanks for the update!
