Ghost Host in Nagios XI 2012R1.2
zahdin
Re: Ghost Host in Nagios XI 2012R1.2
Post by zahdin »
I just added one host and one service, still same issue and can not apply configurations:
Command submitted for processing...
Waiting for configuration verification.....
Configuration verification failed.
An error occurred while attempting to apply your configuration to Nagios Core. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
View a snapshot of this configuration error
Tried CCM->Tools-> write/verify following is output:
Write:
Write host configurations ...
Host configuration files successfully written!
Write service configurations ...
Service configuration files successfully written!
Configuration file: hostgroups.cfg successfully written!
Configuration file: servicegroups.cfg successfully written!
Configuration file: hosttemplates.cfg successfully written!
Configuration file: servicetemplates.cfg successfully written!
Configuration file: timeperiods.cfg successfully written!
Configuration file: commands.cfg successfully written!
Configuration file: contacts.cfg successfully written!
Configuration file: contactgroups.cfg successfully written!
Configuration file: contacttemplates.cfg successfully written!
Configuration file: servicedependencies.cfg successfully written!
Configuration file: hostdependencies.cfg successfully written!
Configuration file: serviceescalations.cfg successfully written!
Configuration file: hostescalations.cfg successfully written!
Configuration file: serviceextinfo.cfg successfully written!
Configuration file: hostextinfo.cfg successfully written!
Verify:
Error: Template 'xiwizard_linuxsnmp_host' specified in host definition could not be not found (config file '/usr/local/nagios/etc/hosts/nagiosxi.cfg', starting on line 14)
Nagios Core 3.4.1
Last Modified: 05-11-2012
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/etc/hosttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicetemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicedependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostdependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/hostescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostextinfo.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceextinfo.cfg'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config file '/usr/local/nagios/etc/hosts/SSG550.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/nagiosxi.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/SSG550M.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/localhost.cfg'...
Processing object config directory '/usr/local/nagios/etc/services'...
Processing object config file '/usr/local/nagios/etc/services/SSG550.cfg'...
Processing object config file '/usr/local/nagios/etc/services/nagiosxi.cfg'...
Processing object config file '/usr/local/nagios/etc/services/SSG550M.cfg'...
Processing object config file '/usr/local/nagios/etc/services/localhost.cfg'...
Restart:
RESTART FAILED. CONFIG ERROR:
Thanks!
Go to CCM -> hosts -> nagiosxi -> Modify
Click Manage templates
just select xiwizard_generic_host Add Selected
remove any others
click close
click save
Go to CCM -> Tools -> Write Config Files
Write
Verify
If Errors post here
If no Errors Restart
zahdin
Post by zahdin »
I do not have any "nagiosxi" under hosts. I have deleted that already.
Lets run the following from the command line
rm -rf /usr/local/nagios/etc/hosts/nagiosxi.cfg
Then back in the web UI apply configuration
