That does look correct, I would restart that worker first, then nagios. No need to restart gearmand.
As for the event handlers, I generally recommend them off too as it is too often in XI that you do not have all the required files/db connections to perform all of the event handlers on the workers.
If you do, that's great and you can turn them on... of course as far as I know there is no way to determine which gearman worker will perform the event handler...
Gearman hostgroup and servicegroups
Re: Gearman hostgroup and servicegroups
Ok, thanks. I'll get to this sometime tomorrow probably and will update the thread with a checkmark if the issue is resolved.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
