Need plugin information
ravish78
Re: Need plugin information
Post by ravish78 »
Yes ,we did the same but no luck
abrist
Red Shirt
Post by abrist »
Could you post your nsc.ini in a code wrap? (obfuscate your password)
CGraham
Post by CGraham »
ravish78,
Just curious if the command works when you run it with the "-n" switch
./check_nrpe -H 13.118.27.40 -n -p 5666 -t 30 -c checkMem -a MaxWarn=80% MaxCrit=90% ShowAll=long type=physical
Have you disabled ssl in your nsc.ini?
use_ssl=0
Yes, run the command with the "-n" flag as subbested by ravish78, and post the output.
Also, check the nsclient.log again - there may be some new entries in it.
ravish78
Post by ravish78 »
tmproot@usa0300lv846>./check_nrpe -H 13.118.27.40 -n -p 5666 -t 30 -c checkMem -a MaxWarn=80% MaxCrit=90% ShowAll=long type=physical
CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages.
getting below error in clinet system nagois log
Could you post your nsc.ini blocking out any sensitive data
Also, are there any errors in the nsclient.log on the remote system?
CGraham
Post by CGraham »
Also, you have to restart nsclient++ service for the changes in your ini to take effect.
ravish78
Post by ravish78 »
I am only seeing this error.
2013-02-18 11:14:08: debug:CACHENSClient++.cpp:557: Attempting to start NSCLient++ - 0.3.9.329 2011-09-02
2013-02-18 11:14:08: message:CACHEmodules\FileLogger\FileLogger.cpp:87: Log path is: C:\NSClient++\\nsclient.log
2013-02-18 11:14:08: error:modules\NSClientListener\NSClientListener.cpp:160: Invalid password (
2013-02-18 13:31:16: error:modules\NSClientListener\NSClientListener.cpp:160: Invalid password (
2013-02-18 14:39:49: message:modules\FileLogger\FileLogger.cpp:86: Starting to log for: NSClient++ - 0.3.9.329 2011-09-02
ravish78
Post by ravish78 »
How can we test this blocking
