Scheduled reports - PDF empty
abrist
Red Shirt
Re: Scheduled reports - PDF empty
Post by abrist »
You may need to check the system time as well:
http://assets.nagios.com/downloads/nagi ... m_Time.pdf
Also, make sure to restart httpd when you change the php.ini timezone:
service httpd restart
Have you thought about upgrading? There are a number of bugs in 2011r3.2 that were fixed throughout the 2012 releases.
Post by slansing »
You may want to look at upgrading to the current version "2012 1.6" as was the solution to the same issue in another thread yesterday:
http://support.nagios.com/forum/viewtop ... f=6&t=9133
driksk8
Post by driksk8 »
I'm trying to upgrade version of Nagios XI with the dedicated procedure but when i run "./update" file, i have a lot of error concerning download of elements on mirror.
It is normal because my nagios server does not have access to internet.
Do you know if it is a problem ?
If it is, do you know a offline method to upgrade nagios ?
Other question : Have I to update version after version or I can update directly to the latest-version (as described in official procedure) ?
If I have to upgarde one by one, i don't know where I can find the intermediate version :(
mguthrie
Post by mguthrie »
Running the upgrade script will immediately bring you to the latest version of Nagios XI.
