yum install perl-Compress-Zlib perl-Compress-Raw perl-IO-Compress-Base perl-IO-Compress-ZlibCode: Select all
yum install perl-Compress-Zlib perl-Compress-Raw-Zlib perl-IO-Compress-Base -yCode: Select all
UUID 0.03 or newerCode: Select all
uname -a
cat /etc/redhat-releaseCode: Select all
This installer has successfully installed both vSphere CLI and the vSphere SDK
for Perl.
The following Perl modules were found on the system but may be too old to work
with vSphere CLI:
Compress::Zlib 2.037 or newer
Compress::Raw::Zlib 2.037 or newer
IO::Compress::Base 2.037 or newer
IO::Compress::Zlib::Constants 2.037 or newer
LWP::Protocol::https 5.805 or newer
Linux pfsunagiosxi.prodsydney.com.au 2.6.32-279.5.1.el6.x86_64 #1 SMP Tue Aug 14 23:54:45 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
CentOS release 6.3 (Final)
chown nagios.nagcmd /usr/local/nagiosxi/html/includes/configwizards/vmware/scripts/getguests.pl
chmod 775 /usr/local/nagiosxi/html/includes/configwizards/vmware/scripts/getguests.pl
cd /tmp
tar zxf VMware-vSphere-Perl-SDK-5.1.0-780721.x86_64.tar
yum clean all
yum install perl-XML-SAX -y
yum install perl-Nagios-Plugin libuuid* perl-XML-LibXML -y
yum install perl-Class-MethodMaker perl-Archive-Zip perl-Data-Dump perl-SOAP-Lite -y
cd /tmp
wget --directory-prefix=/tmp http://search.cpan.org/CPAN/authors/id/J/JN/JNH/UUID-0.04.tar.gz
tar xzf UUID-0.04.tar.gz -C /tmp
cd /UUID-0.04
perl Makefile.PL
make
make install
CPAN
cd /tmp
export http_proxy=
export ftp_proxy=
cd vmware-vsphere-cli-distrib
./vmware-install.pl
for Perl.
with vSphere CLI:
version 0.78 or newer
Enjoy,
--the VMware team
