Web Interface not launching
estherpeddi
Re: Web Interface not launching
Post by estherpeddi »
How do i post the screenshot?
Edit: sestatus is disabled.
Reason: Please edit your previous post as long as nobody has posted after you instead of adding multiple new posts, this helps keep clutter down, and helps us to assist you faster.
Post by slansing »
Do you have the screenshot saved locally? If so click the attach button when creating a new post in this thread and upload it.
Alternatively you could upload it to a image hosting site.
If you do not know how to capture a screenshot, bring the console screen that you are working up on your monitor and press the Print Screen key on your keyboard, then open paint "if using Windows." From here click Edit, then paste, then click file, and save the image as a .jpg/jpeg. Then attach as I indicated above.
estherpeddi
Screenshot attached.
It appears that for some reason, you were not assigned an IP address... Can you, please, run the following command as root in terminal, and show the output?
cat /etc/sysconfig/network-scripts/ifcfg-eth0
Is your Network Adapter in VMware Player (or VMWare Workstation) set to "Bridged" or "NAT"?
estherpeddi
Please confirm if you were able to see the attachments
abrist
Red Shirt
Post by abrist »
We can see the screenshot, it does not appear that networking has been brought up on the box. Post the output of:
ifconfig eth0
As lmiltchev asked, what network settings is your VM configured for? Bridged? NAT? None?
estherpeddi
Im using vmware player
Edit 1: How do i check the vmware settings?
Edit 2: Ok i found it, it says Bridged.
abrist
Red Shirt
Post by abrist »
Could you post the output of the following commands (enter them into the command line interface) on the XI box?
ifconfig eth0
You will probably have to run the following:
ifconfig eth0 up
dhclient eth0
ping google.com
estherpeddi
I was able to run all the commands, what is the next step
estherpeddi
Ok, i'm able to launch web interface now. Thanks so much for all the help!!!
