Do you know if they left something in place that could be redirecting localhost traffic?disrael wrote: I think the DC team used a tunnel or something to access yum.
Can you run
cat /etc/hosts|grep localhostthanks
cat /etc/hosts|grep localhostCode: Select all
127.0.0.1 localhost.localdomain localhost
cat /usr/local/nagios/etc/ndo2db.cfg
# NDO2DB DAEMON CONFIG FILE
lock_file=/usr/local/nagios/var/ndo2db.lock
ndo2db_user=nagios
ndo2db_group=nagios
socket_type=unix
socket_name=/usr/local/nagios/var/ndo.sock
tcp_port=5668
db_servertype=mysql
db_host=localhost
db_port=3306
db_name=nagios
db_prefix=nagios_
db_user=ndoutils
db_pass=n@gweb
## TABLE TRIMMING OPTIONS
# Several database tables containing Nagios event data can become quite large
# over time. Most admins will want to trim these tables and keep only a
# certain amount of data in them. The options below are used to specify the
# age (in MINUTES) that data should be allowd to remain in various tables
# before it is deleted. Using a value of zero (0) for any value means that
# that particular table should NOT be automatically trimmed.
# Keep timed events for 24 hours
max_timedevents_age=1440
# Keep system commands for 1 week
max_systemcommands_age=10080
# Keep service checks for 1 week
max_servicechecks_age=10080
# Keep host checks for 1 week
max_hostchecks_age=10080
# Keep event handlers for 31 days
max_eventhandlers_age=44640
# DEBUG LEVEL
# be written to the debug file. OR values together to log multiple
# types of information.
# Values: -1 = Everything
# 0 = Nothing
# 1 = Process info
# 2 = SQL queries
debug_level=0
# DEBUG VERBOSITY
# This option determines how verbose the debug log out will be.
# Values: 0 = Brief output
# 1 = More detailed
# 2 = Very detailed
debug_verbosity=1
# DEBUG FILE
# This option determines where the daemon should write debugging information.
debug_file=/usr/local/nagios/var/ndo2db.debug
# MAX DEBUG FILE SIZE
# This option determines the maximum size (in bytes) of the debug file. If
# the file grows larger than this size, it will be renamed with a .old
# extension. If a file already exists with a .old extension it will
# automatically be deleted. This helps ensure your disk space usage doesn't
# get out of control when debugging.
max_debug_file_size=1000000
service ndo2db restartCode: Select all
Stopping ndo2db: head: cannot open `/usr/local/nagios/var/ndo2db.lock' for reading: No such file or directory
done.
Starting ndo2db: done.
pel-release RPM installed OK
Removing rpm php-pdo-5.3.3-14.el6_3.x86_64 from install
Removing rpm fontconfig-devel-2.8.0-3.el6.x86_64 from install
Removing rpm perl-Parse-RecDescent-1.965-1.el6.noarch from install
Removing rpm libXaw-1.0.6-4.1.el6.x86_64 from install
Removing rpm rrdtool-perl-1.3.8-6.el6.x86_64 from install
Removing rpm perl-Net-SMTP-TLS-0.12-1.el6.rf.noarch from install
Removing rpm php-pgsql-5.3.3-14.el6_3.x86_64 from install
Removing rpm php-xml-5.3.3-14.el6_3.x86_64 from install
Removing rpm libXau-devel-1.0.5-1.el6.x86_64 from install
Removing rpm libXpm-devel-3.5.8-2.el6.x86_64 from install
Removing rpm perl-DBD-MySQL-4.013-3.el6.x86_64 from install
Removing rpm dejavu-sans-mono-fonts-2.30-2.el6.noarch from install
Removing rpm perl-DateTime-0.5300-1.el6.x86_64 from install
Removing rpm php-gd-5.3.3-14.el6_3.x86_64 from install
Removing rpm fping-3.4-1.el6.rf.x86_64 from install
Removing rpm php-common-5.3.3-14.el6_3.x86_64 from install
Removing rpm postgresql-8.4.13-1.el6_3.x86_64 from install
Removing rpm perl-Net-SSLeay-1.35-9.el6.x86_64 from install
Removing rpm libmcrypt-2.5.8-9.el6.x86_64 from install
Removing rpm libxcb-devel-1.5-1.el6.x86_64 from install
Removing rpm perl-SNMP_Session-1.12-4.el6.noarch from install
Removing rpm perl-Net-LibIDN-0.12-3.el6.x86_64 from install
Removing rpm perl-Crypt-DES-2.05-9.el6.x86_64 from install
Removing rpm libjpeg-devel-6b-46.el6.x86_64 from install
Removing rpm dejavu-lgc-sans-mono-fonts-2.30-2.el6.noarch from install
Removing rpm rpmdevtools-7.5-1.el6.noarch from install
Removing rpm perl-Net-SNMP-5.2.0-4.el6.noarch from install
Removing rpm mrtg-2.16.2-5.el6.x86_64 from install
Removing rpm perl-Net-DNS-0.65-4.el6.x86_64 from install
Removing rpm php-ldap-5.3.3-14.el6_3.x86_64 from install
Removing rpm perl-XML-Simple-2.18-6.el6.noarch from install
Removing rpm expat-devel-2.0.1-11.el6_2.x86_64 from install
Removing rpm pymssql-1.0.2-4.el6.x86_64 from install
Removing rpm postgresql-libs-8.4.13-1.el6_3.x86_64 from install
Removing rpm php-cli-5.3.3-14.el6_3.x86_64 from install
Removing rpm perl-Digest-SHA1-2.12-2.el6.x86_64 from install
Removing rpm libXdmcp-devel-1.0.3-1.el6.x86_64 from install
Removing rpm mrtg-libs-2.16.2-5.el6.x86_64 from install
Removing rpm perl-IO-Socket-SSL-1.31-2.el6.noarch from install
Removing rpm perl-Class-Singleton-1.4-6.el6.noarch from install
Removing rpm fakeroot-libs-1.12.2-22.2.el6.x86_64 from install
Removing rpm rrdtool-1.3.8-6.el6.x86_64 from install
Removing rpm gd-devel-2.0.35-10.el6.x86_64 from install
Removing rpm libmcrypt-devel-2.5.8-9.el6.x86_64 from install
Removing rpm php-mysql-5.3.3-14.el6_3.x86_64 from install
Removing rpm postgresql-devel-8.4.13-1.el6_3.x86_64 from install
Removing rpm php-snmp-5.3.3-14.el6_3.x86_64 from install
Removing rpm perl-Mail-POP3Client-2.18-6.el6.noarch from install
Removing rpm php-mssql-5.3.3-1.el6.x86_64 from install
Removing rpm xorg-x11-proto-devel-7.6-13.el6.noarch from install
Removing rpm perl-Digest-HMAC-1.01-22.el6.noarch from install
Removing rpm libX11-devel-1.3-2.el6.x86_64 from install
Removing rpm perl-List-MoreUtils-0.22-10.el6.x86_64 from install
Removing rpm fakeroot-1.12.2-22.2.el6.x86_64 from install
Removing rpm graphviz-2.26.0-7.el6.x86_64 from install
Removing rpm php-mcrypt-5.3.3-1.el6.x86_64 from install
Removing rpm postgresql-server-8.4.13-1.el6_3.x86_64 from install
Removing rpm nmap-5.51-2.el6.x86_64 from install
Removing rpm perl-Socket6-0.23-3.el6.x86_64 from install
Removing rpm perl-IO-Socket-INET6-2.56-4.el6.noarch from install
Removing rpm perl-Params-Validate-0.92-3.el6.x86_64 from install
Removing rpm libpng-devel-1.2.49-1.el6_2.x86_64 from install
Removing rpm rrdtool-python-1.3.8-6.el6.x86_64 from install
Removing rpm perl-Mail-IMAPClient-3.32-1.el6.noarch from install
Removing rpm php-5.3.3-14.el6_3.x86_64 from install
Removing rpm xinetd-2.3.14-35.el6_3.x86_64 from installCode: Select all
Feb 18 13:22:07 usa7061lv981 nagios: ndomod: Error writing to data sink! Some output may get lost...
Feb 18 13:22:07 usa7061lv981 nagios: ndomod: Please check remote ndo2db log, database connection or SSL Parameters
Feb 18 13:22:07 usa7061lv981 nagios: Successfully shutdown... (PID=9947)
Feb 18 13:22:07 usa7061lv981 nagios: ndomod: Shutdown complete.
Feb 18 13:22:07 usa7061lv981 nagios: Event broker module '/usr/local/nagios/bin/ndomod.o' deinitialized successfully.
Feb 18 13:22:07 usa7061lv981 nagios: Nagios 3.4.1 starting... (PID=15904)
Feb 18 13:22:07 usa7061lv981 nagios: Local time is Mon Feb 18 13:22:07 EST 2013
Feb 18 13:22:07 usa7061lv981 nagios: LOG VERSION: 2.0
Feb 18 13:22:07 usa7061lv981 nagios: ndomod: NDOMOD 1.5.1 (05-15-2012) Copyright (c) 2009 Nagios Core Development Team and Community Contributors
Feb 18 13:22:07 usa7061lv981 nagios: ndomod: Successfully connected to data sink. 8 queued items to flush.
Feb 18 13:22:07 usa7061lv981 nagios: ndomod: Successfully flushed 8 queued items to data sink.
Feb 18 13:22:07 usa7061lv981 nagios: Event broker module '/usr/local/nagios/bin/ndomod.o' initialized successfully.
Feb 18 13:22:07 usa7061lv981 nagios: Finished daemonizing... (New PID=15908)
Feb 18 13:22:07 usa7061lv981 ndo2db: Error: queue send error, retrying...
Feb 18 13:22:08 usa7061lv981 ndo2db: Message sent to queue
Feb 18 13:22:08 usa7061lv981 ndo2db: Error: queue send error, retrying...
Feb 18 13:22:09 usa7061lv981 ndo2db: Message sent to queue
Feb 18 13:22:09 usa7061lv981 ndo2db: Error: queue send error, retrying...
Feb 18 13:22:10 usa7061lv981 ndo2db: Message sent to queue
Feb 18 13:22:10 usa7061lv981 ndo2db: Error: queue send error, retrying...
Feb 18 13:22:11 usa7061lv981 ndo2db: Message sent to queue
Feb 18 13:23:01 usa7061lv981 automount[5706]: key "nagios" not found in map source(s).
Feb 18 13:23:38 usa7061lv981 nagios: Caught SIGTERM, shutting down...
Feb 18 13:23:38 usa7061lv981 nagios: ndomod: Error writing to data sink! Some output may get lost...
Feb 18 13:23:38 usa7061lv981 nagios: ndomod: Please check remote ndo2db log, database connection or SSL Parameters
Feb 18 13:23:38 usa7061lv981 nagios: Successfully shutdown... (PID=15908)
Feb 18 13:23:38 usa7061lv981 nagios: ndomod: Shutdown complete.
Feb 18 13:23:38 usa7061lv981 nagios: Event broker module '/usr/local/nagios/bin/ndomod.o' deinitialized successfully.
Feb 18 13:23:38 usa7061lv981 nagios: Nagios 3.4.1 starting... (PID=16657)
Feb 18 13:23:38 usa7061lv981 nagios: Local time is Mon Feb 18 13:23:38 EST 2013
Feb 18 13:23:38 usa7061lv981 nagios: LOG VERSION: 2.0
Feb 18 13:23:38 usa7061lv981 nagios: ndomod: NDOMOD 1.5.1 (05-15-2012) Copyright (c) 2009 Nagios Core Development Team and Community Contributors
Feb 18 13:23:38 usa7061lv981 nagios: ndomod: Successfully connected to data sink. 8 queued items to flush.
Feb 18 13:23:38 usa7061lv981 nagios: ndomod: Successfully flushed 8 queued items to data sink.
Feb 18 13:23:38 usa7061lv981 nagios: Event broker module '/usr/local/nagios/bin/ndomod.o' initialized successfully.
Feb 18 13:23:38 usa7061lv981 nagios: Finished daemonizing... (New PID=16661)
Feb 18 13:23:38 usa7061lv981 ndo2db: Error: queue send error, retrying...
Feb 18 13:23:39 usa7061lv981 ndo2db: Message sent to queue
Feb 18 13:23:39 usa7061lv981 ndo2db: Error: queue send error, retrying...
Feb 18 13:23:40 usa7061lv981 ndo2db: Message sent to queue
Feb 18 13:23:40 usa7061lv981 ndo2db: Error: queue send error, retrying...
Feb 18 13:23:41 usa7061lv981 ndo2db: Message sent to queue
Feb 18 13:23:41 usa7061lv981 ndo2db: Error: queue send error, retrying...
Feb 18 13:23:42 usa7061lv981 ndo2db: Message sent to queue
Feb 18 13:24:21 usa7061lv981 sshd[16875]: rexec line 51: Deprecated option RhostsAuthentication
Feb 18 13:25:01 usa7061lv981 automount[5706]: key "nagios" not found in map source(s).
Feb 18 13:25:29 usa7061lv981 rsyslogd-2177: imuxsock begins to drop messages from pid 11795 due to rate-limiting
Unfortunately, I do not have a fix for this... You should never run fullinstall on a system already running Nagios XI...disrael wrote:after I tried running ./fullinstall -o again.
We still have the same issue on a different server. I can have this one re-imaged, though i would like to know why it is doing what it is so we don't run into this issue when we upgrade via yum. Are we even supposed to do upgrade via yum?scottwilkerson wrote:Doran,
The only way I can see out of this would be to take your most recent backup move it off of the server, reinstall a fresh machine and then restore the backup.
