Help!?
Re: Help!?
The task has been completed.
Will the file automatically be created, or do I have to create the file?
Status:
susetestbox:/usr/local/nagios/etc/objects # ls -la /var/lib/ | grep mrtg
drwxr-xr-x 1 nagios nagios 0 Mar 4 16:31 mrtg
susetestbox:/usr/local/nagios/etc/objects # ls -la /var/lib/mrtg
total 0
drwxr-xr-x 1 nagios nagios 0 Mar 4 16:31 .
drwxr-xr-x 1 root root 1200 Mar 4 16:31 ..
Status:
total 0
Re: Help!?
The mrtg folders *should* be auto-created. You have to wait until 2 checks for each service have been received.
Re: Help!?
It seems that the graph charts are not generating at all, even though the mrtg directory was created yesterday and mrtg was installed since January.
susetestbox:/var/lib/mrtg # ps flax | grep nagios
0 0 31451 24585 20 0 2528 488 - S+ pts/0 0:00 \_ grep --color=auto nagios
5 113 2062 1 20 0 4088 16 - Ss ? 1:11 /usr/sbin/nrpe -c /etc/nagios/nrpe.cfg -d
1 113 12989 1 20 0 11276 1328 - Ssl ? 0:59 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
susetestbox:/var/lib/mrtg # ls -al /var/lib/mrtg/
total 0
I do not know if this is the problem, but I do not know if I have to manually configured each log file:
susetestbox:/usr/local/nagios/lib # more check_mrtg
******** check_mrtg: Not a text file ********
susetestbox:/usr/local/nagios/lib # more check_mrtgtraf
******** check_mrtgtraf: Not a text file ********
total 0
Re: Help!?
Also, MRTG is running as well:
susetestbox:/usr/local/nagios/etc/objects # ps flax | grep mrtg
0 0 32749 24585 20 0 2528 488 pipe_w S+ pts/0 0:00 \_ grep --color=auto mrtg
Re: Help!?
Run this command to update mrtg log file.
Check crond to make sure you have a few entries that reseble:
env LANG=C /usr/bin/mrtg /etc/mrtg/mrtg.cfgCode: Select all
/5 * * * * /usr/bin/env LANG=C /usr/bin/mrtg /etc/mrtg/mymrtg.cfg –logging /var/log/mrtg.log
*/5 * * * * /usr/bin/env LANG=C /usr/bin/mrtg /etc/httpd/conf/mrtg.cfg --logging /var/log/mrtg.logFormer Nagios employee
Re: Help!?
susetestbox:/usr/local/nagios/etc/objects # env LANG=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg
2013-03-06 09:25:35: ERROR: Creating templock /etc/mrtg/mrtg.cfg_l_22680: No such file or directory at /usr/bin/mrtg line 1969.
susetestbox:/usr/local/nagios/etc/objects # grep mrtg
^C
susetestbox:/usr/local/nagios/etc/objects # cd
susetestbox:~ # grep mrtg
^C
susetestbox:~ # susetestbox:/usr/local/nagios/etc/objects # env LANG=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg
-bash: susetestbox:/usr/local/nagios/etc/objects: No such file or directory
susetestbox:~ # 2013-03-06 09:25:35: ERROR: Creating templock /etc/mrtg/mrtg.cfg_l_22680: No such file or directory at /usr/bin/mrtg line 1969.
If '2013-03-06' is not a typo you can use command-not-found to lookup the package that contains it, like this:
cnf 2013-03-06
susetestbox:~ # */5 * * * * /usr/bin/env LANG=C /usr/bin/mrtg /etc/httpd/conf/mrtg.cfg --logging /var/log/mrtg.log
-bash: */5: No such file or directory
susetestbox:~ # /5 * * * * /usr/bin/env LANG=C /usr/bin/mrtg /etc/mrtg/mymrtg.cfg .logging /var/log/mrtg.log
-bash: /5: No such file or directory
^C
^C
cnf 2013-03-06
Re: Help!?
These are lines in a cron file, not commands. To possibly see if you have any of these entries, run:abrist wrote: Check crond to make sure you have a few entries that reseble:Code: Select all
/5 * * * * /usr/bin/env LANG=C /usr/bin/mrtg /etc/mrtg/mymrtg.cfg –logging /var/log/mrtg.log */5 * * * * /usr/bin/env LANG=C /usr/bin/mrtg /etc/httpd/conf/mrtg.cfg --logging /var/log/mrtg.log
cat /etc/cron*/* | grep mrtgFormer Nagios employee
Re: Help!?
Status:
susetestbox:~ # cat /etc/cron*/* | grep mrtg
susetestbox:~ #
susetestbox:~ #
Re: Help!?
It looks like you do not have any cron jobs setup for mrtg. How did you install core?
Re: Help!?
Reviewing the instruction from this website:
http://nagios.sourceforge.net/docs/3_0/ ... nsuse.html
