service freshness problem
dzaro
Re: service freshness problem
Post by dzaro »
Yes, this is the same problem. I applied the patch and it seems to work now. I'll know in a week or so if my service will get stale. I'll let you know.
So if this is a known bug, even fixed in icinga, will it be fixed or i'll have to patch it every time i decide to upgrade nagios? :)
Thank you
abrist
Red Shirt
Post by abrist »
Once the bug is confirmed by our core developer,I am sure it will get rolled into a future core update.
We applied a patch to the trunk today that correctly fixes the issue instead of just deleted the section like the other patch did.
Attached is the new patch and will be applied in 3.5.1 when it is released.
freshness.zip
(368 Bytes) Downloaded 432 times
dzaro
Post by dzaro »
Hell,
I applied the patch and it seems to work as expected now.
Thank You
