NRDP Issue
BanditBBS
Re: NRDP Issue
Post by BanditBBS »
scottwilkerson wrote:Hmm, something doesn't seem right, these are just the .ok files, can you run
ls -ld /usr/local/nagios/var/spool/checkresults
drwxrwxr-x. 2 nagios nagios 4096 Feb 27 17:20 /usr/local/nagios/var/spool/checkresults
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
mguthrie
Re: NRDP Issue
Post by mguthrie »
Just a thought on this, these are notes from the NRDP config.inc.php file.
// the name of the system group that has write permissions to the external command file
// this group is also used to set file permissions when writing bulk commands or passive check results
// NOTE: both the Apache and Nagios users must be a member of this group
$cfg["nagios_command_group"]="nagcmd";
I'm noticing that the files are all owned apache:apache.
BanditBBS
Re: NRDP Issue
Post by BanditBBS »
mguthrie wrote:Just a thought on this, these are notes from the NRDP config.inc.php file.
So what do you suggest Mike? nagcmd is what that is set too in my config file.
Re: NRDP Issue
BanditBBS,
I think we may need to see the whole picture, can you send me your latest snapshot as well as your /usr/local/nrdp/server/config.inc.php to [email protected]
Please reference this thread
thanks.
BanditBBS
Re: NRDP Issue
Post by BanditBBS »
Email sent
Re: NRDP Issue
I am going to lock this as it will be completed via email.
Re: NRDP Issue
Final update on this, it was resolved after finding that the nagios user was not part of the nagcmd group
usermod -a -G nagcmd nagios
