2012 R1.6 : apply configuration doesn't work
Frédéric GRANAT
Re: 2012 R1.6 : apply configuration doesn't work
I've got several files named cmdsubsys
cmdsubsys.log
cmdsubsys.log.1
cmdsubsys.log.2
cmdsubsys.log.3
cmdsubsys.log.4
I run "Apply configuration"
vi of first file : empty file
Other files :
PROCESSED 0 COMMANDS
cmdsubsys.log
cmdsubsys.log.1
cmdsubsys.log.2
cmdsubsys.log.3
cmdsubsys.log.4
Other files :
Lets see if these files are empty, run the following:
Keep in mind we asked to see the tail of the files, not what they show when opened in an editor, these can provide different results
ls -la /usr/local/nagiosxi/var/ | grep subsys-
Frédéric GRANAT
Here it's
-rw-r--r-- 1 nagios nagios 0 Mar 11 17:13 cmdsubsys.log
-rw-r--r-- 1 nagios nagios 82 Feb 24 04:03 cmdsubsys.log.1
-rw-r--r-- 1 nagios nagios 82 Feb 17 04:03 cmdsubsys.log.2
-rw-r--r-- 1 nagios nagios 81 Feb 10 04:03 cmdsubsys.log.3
-rw-r--r-- 1 nagios nagios 82 Feb 3 04:03 cmdsubsys.log.4
Is crond running? Do a running tail on /var/log/cron and then try killing all cron instances and restart it. Send the tail back.
tail -f /var/log/cron
service crond stop
ps -aef | grep crond
killall crond
service crond startFormer Nagios employee
Frédéric GRANAT
Do a running tail on /var/log/cron Send the tail back.
=> How can I do to kill all cron instances ?
[root@nagiosxi var]# tail -f /var/log/cron
Mar 11 18:16:01 nagiosxi crond[3328]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php > /usr/local/nagiosxi/var/cleaner.log 2>&1)
Mar 11 18:16:01 nagiosxi crond[3329]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php > /usr/local/nagiosxi/var/reportengine.log 2>&1)
Mar 11 18:16:01 nagiosxi crond[3332]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php > /usr/local/nagiosxi/var/nom.log 2>&1)
Mar 11 18:16:01 nagiosxi crond[3334]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Mar 11 18:16:01 nagiosxi crond[3336]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1)
Mar 11 18:16:01 nagiosxi crond[3337]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1)
Mar 11 18:16:01 nagiosxi crond[3338]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Mar 11 18:16:02 nagiosxi crond[3346]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1)
Mar 11 18:16:02 nagiosxi crond[3348]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosfusion/cron/cmdsubsys.php > /usr/local/nagiosfusion/var/cmdsubsys.log 2>&1)
Mar 11 18:16:02 nagiosxi crond[3356]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosfusion/cron/eventman.php > /usr/local/nagiosfusion/var/eventman.log 2>&1)
[root@nagiosxi var]# killall crond
crond: no process killed
If you stopped the crond service and the "killall" command "reports no process killed", this means that crond was functioning normally (no orphaned procs or multiple crond parent instances). Remember to restart crond:
After the crond restart, are things functioning normally?
Frédéric GRANAT
Unfortunately not
Aditional information : System status show many components off since the upgrade (see the attached file).
And when trying to restart nagios :
Rgds
> service nagios restart
Running configuration check... CONFIG ERROR! Restart aborted. Check your Nagios configuration.
Can you post the contents of the following file?
/etc/cron.d/nagiosxi
And also run
And also run
chown nagios.nagios /usr/local/nagiosxi/var/*.log
service crond restart-
Frédéric GRANAT
# /etc/cron.d/nagiosxi: crontab fragment for nagiosxi
# Backup MySQL & PostgreSQL Databases
0 7 * * * root /root/scripts/automysqlbackup
0 8 * * * root /root/scripts/autopostgresqlbackup
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/nom.php > /usr/local/nagiosxi/var/nom.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php > /usr/local/nagiosxi/var/reportengine.log 2>&1
*/5 * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php > /usr/local/nagiosxi/var/dbmaint.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php > /usr/local/nagiosxi/var/cleaner.log 2>&1
01 * * * * nagios /usr/local/nagiosxi/cron/recurringdowntime.pl > /usr/local/nagiosxi/var/recurringdowntime.log 2>&1
*/5 * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php > /usr/local/nagiosxi/var/deadpool.log 2>&1
Can you post the output from the following command:
su nagios -c '/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php'
