Actions component
Re: Actions component
While somewhat weird can you try installing this modified component
no good
ant this is what I get when I run the command:
I hit enter on the tail command, that immediately pops up. then I save my actions settings. and no new info is displayed.
then I save my actions settings and then run the command and that's all I get.
[Tue Mar 05 18:38:24 2013] [error] [client 172.22.27.159] PHP Warning: array_key_exists() expects parameter 2 to be array, null given in /usr/local/nagiosxi/html/includes/dbauth.inc.php on line 372, referer: http://172.22.2.123/nagiosxi/includes/components/opscreen/opscreen.php
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
This is an error from yesterday... And is about opscreen, not the actions component
that's the crazy thing I don't get any errors for actions.
scott is there a way to uninstall the component and clear wherever it saves its configuration? that way I can reinstall it "clean" maybe that will do it, the file coulda got corrupt or something.
Proudly running:
Nagios Fusion
Nagios Fusion
yes.
Remove the action component from Admin -> Manage Components (red X)
then run this from the command line
Finally, you can reinstall the component
echo "delete from xi_options where name ='actions_component_options';"|psql nagiosxi nagiosxiRe: Actions component
my server is haunted man...
[root@LkennagiosP01 ~]# echo "delete from xi_options where name ='actions_component_options';"|psql nagiosxi nagiosxi
psql: could not connect to server: No such file or directory
Is the server running locally and accepting
connections on Unix domain socket "/tmp/.s.PGSQL.5432"?
Proudly running:
Nagios Fusion
Nagios Fusion
Scott I dont know if it makes a difference, but when I save the settings without designating anything, then the change is applied globally. it's only when I try to select something and save that it fails.
Proudly running:
Nagios Fusion
Nagios Fusion
Is postgresql running?benhank wrote:my server is haunted man...
[root@LkennagiosP01 ~]# echo "delete from xi_options where name ='actions_component_options';"|psql nagiosxi nagiosxi psql: could not connect to server: No such file or directory Is the server running locally and accepting connections on Unix domain socket "/tmp/.s.PGSQL.5432"? [root@LkennagiosP01 ~]#
service postgresql statusCode: Select all
tail /var/lib/pgsql/data/pg_logRe: Actions component
[root@LkennagiosP01 ~]# tail /var/lib/pgsql/data/pg_log
tail: error reading `/var/lib/pgsql/data/pg_log': Is a directory
Proudly running:
Nagios Fusion
Nagios Fusion
sreinhardt
- -fno-stack-protector
ok, lets go for the logs denoted by day of the week. Since today is thurs, /var/lib/pgsql/data/pg_log/postgresql-Thu.log. If you have not used it today, choose another day when you have.
