Nagios on XenServer 5.5
abrist
Red Shirt
Re: Nagios on XenServer 5.5
Post by abrist »
Post the output of the following:
echo $PATH
brianweeks22
Post by brianweeks22 »
[root@XenHost8 nrpe-2.14]# echo $PATH
/opt/xensource/bin:/opt/xensource/bin:/opt/xensource/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin
sreinhardt
-fno-stack-protector
Post by sreinhardt »
What base OS is your xen server? You will need to install some form of C compiler. I take it that previously you were using an rpm packaged? You can probably do a "yum install gcc" or if it is debian based "apt-get install gcc". Then try to run configure again.
brianweeks22
[root@XenHost8 nrpe-2.14]# cat /proc/version
Linux version 2.6.32.12-0.7.1.xs6.0.2.542.170665xen (geeko@buildhost) (gcc version 4.1.2 20080704
(Red Hat 4.1.2-48)) #1 SMP Tue Jan 17 15:14:24 EST 2012
I am running Red hat 4.1 and it appears as if GCC is already installed
abrist
Red Shirt
Post by abrist »
Lets check it's location:
find / -name gcc
brianweeks22
[root@XenHost8 nrpe-2.14]# find / -name gcc
returned a blank line
sreinhardt
It would seem that it is not installed, and instead the gcc output above from cat /proc/version is just listing what your kernel was compiled with. So let's try a "yum install gcc" the ./configure once it is installed with all the needed dependencies. If it errors again, send back the output and we can see how far it has gotten.
brianweeks22
yet another roadblock
[root@XenHost8 opt]# yum install gcc
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
Setting up Install Process
No package gcc available.
Nothing to do
sreinhardt
Before I give instructions on making and compiling gcc as well, it looks like yum may not have been the main package manager for RHEL 4. Try "up2date gcc"
brianweeks22
[root@XenHost8 opt]# up2date gcc
bash: up2date: command not found
[root@XenHost8 opt]# yum install up2date gcc
No package up2date available.
Nothing to do
