Compiling nrpe on AIXv6.1
akrishnan
Re: Compiling nrpe on AIXv6.1
Post by akrishnan »
I got reply from IBM. Per instructions I installed the krb5.toolkit.1.4.0.7.I. The toolkit had installed the following files:
Path: /usr/lib/objrepos
krb5.toolkit.adt 1.4.0.7
/usr/include/gssapi/gssapi_krb5.h
/usr/include/ibm_svc/krb5kdc.h
/usr/include/gssapi/gssapi_generic.h
/usr/include/k5profile.h
/usr/include/ibm_svc/krb5_svc.h
/usr/include/ibm_svc/krb5adm.h
/usr/include/com_err.h
/usr/include/gssapi/gssapi.h
/usr/include/gssapi
/usr/include/krb5.h
/usr/include/kadm5
/usr/include/kadm5/admin.h
/usr/include/kdb_types.h
/usr/include/ibm_svc/krb5krb.h
/usr/include/ibm_svc/krb5vdb.h
/usr/include/ibm_svc/krb5utl.h
/usr/include/ibm_svc/krb5gss.h
So I executed the ./configure command. Still getting the following error:
checking for main in -lwrap... no
checking for strdup... yes
checking for strstr... yes
checking for strtoul... yes
checking for initgroups... yes
checking for closesocket... no
checking for socklen_t... yes
checking for type of socket size... size_t
checking for SSL headers... SSL headers found in /usr
checking for SSL libraries... SSL libraries found in /usr/lib
*** Generating DH Parameters for SSL/TLS ***
Generating DH parameters, 512 bit long safe prime, generator 2
This is going to take a long time
checking for Kerberos include files... could not find include files
checking for perl... /bin/perl
configure: creating ./config.status
config.status: creating Makefile
config.status: creating subst
config.status: creating src/Makefile
config.status: creating package/solaris/Makefile
config.status: creating init-script
config.status: creating init-script.debian
config.status: creating init-script.suse
config.status: creating nrpe.spec
config.status: creating sample-config/nrpe.cfg
config.status: creating sample-config/nrpe.xinetd
config.status: creating include/config.h
config.status: include/config.h is unchanged
Any suggestions as to which Kerberos include files are not found?
I would like to thank the support team for their patience and guidance.
abrist
Red Shirt
Post by abrist »
Did you make sure the new (ibm supplied) files were in your path before compile?
Is kerberos support necessary in your environment? It should still compile without them.
akrishnan
Post by akrishnan »
I do have the /usr/include in the $PATH. Here is the output:
echo $PATH
/bin:/usr/bin:/usr/sbin:/etc:/usr/ucb:/usr/bin/X11:/sbin:/usr/local/bin:/tools/bin:/usr/lpp/X11/Lib:/usr/lpp/ssp/bin:/usr/vac/bin:/usr/local/etc:/usr/local/scripts:/usr/include
What are the include files, the nagios configure process is looking for? In my environment, krb5 is used. Thanks.
abrist
Red Shirt
Post by abrist »
krb5 is supported by nrpe and is the assumed implementation of kerberos in the nrpe's installer.
