You do not have the "Listen" directive declared in your httpd.conf. Additionally, you should check the path to "ServerRoot" for your config files (vhosts etc.).
Add "Listen 77" near the top of your httpd.conf and restart apache (without the quotes).
How did you install apache?
We need to stop for a moment here. If neither the apache2 nor httpd bin exists, something is not right.
What distribution are you running?
Just for your information, you should find your apache configs in the directory: /usr/local/apache2/conf
I can look into /usr/local/apache2/conf file. I don't have any issues regarding that....
Here is by distro version for linux...
Linux version 2.6.9-42.ELsmp ([email protected]) (gcc version 3.4.6 20060404 (Red Hat 3.4.6-2)) #1 SMP Wed Jul 12 23:27:17 EDT 2006
I have installed my apache using the tar file which was downloaded from apache.org website..... I don't think with out those files my apache would start or stop mainly httpd.conf....
Today's I see this message after I hit my username and password....
You may have wanted to install apache from the rehat repos as I bet that you are missing a number of important apache modules. If you want to stick with your current install, be ready for a long road of support to get it working. It looks like you do not have have certain scripts and the location of the apache bin is a mystery. Lets find the bin:
/usr/bin/which: no apache2 in (/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/X11R6/bin:/root/bin)
/usr/bin/which: no httpd in (/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/X11R6/bin:/root/bin)
Correct me If I am wrong. So, You would want me to reinstall apache? As you said, I see only two files in my modules directory i.e., phplib5.so and httpd.exe
Also, Can you help me providing the link to download correct set of apache for nagios. It might sound funny to ask you,but please do help.
Did you by chance download the *windows* tarball? You normally do not see .exe file extensions for linux binaries.
Due to the nature of this problem, it is becoming increasingly hard to support your installation as the problems we are seeing are not with Nagios but rather Apache. While we do our best to support all issues, we generally only support installations based on a fresh system and not installations which try to work in per-existing configurations of packages Nagios depends on to run properly. In this case, we recommend that you either bring up a fresh system on one of the supported operating systems which will already have a cleanly configured version of Apache and from there we can support the Nagios side of the server. We also recommend that if you do plan to try and work in your choice of Apache packages that you contact the Apache support group in order to verify that you have correctly installed and integrated Apache into the server.
