This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
Posts: 19396 Joined: Tue Nov 15, 2011 3:11 pm
Post
by scottwilkerson » Tue Apr 23, 2013 1:16 pm
If you go to the service status detail page for this service what is displayed?
Looking at this again, I'm not positive that this plugin conforms to the threshold standards, lets also try with $ARG1$ as
-U 'sa' -P 'my sa pwd' -p myport --deadlocks --warning 5 --critical 10
maxwellmiranda
Posts: 113 Joined: Thu Mar 22, 2012 3:24 pm
Post
by maxwellmiranda » Mon May 06, 2013 1:55 pm
how do i monitor a non default instance on sql server
i am trying the below query at the command line
./check_mssql_database.py -H 'usmasql1.bose.com' -U 'nagios' -P 'nagios' -I USMASQL1\USMASQL1 -T 'master' -p 1433 --time2connect --warning 1 --critical 5
my sql instance is USMASQL1
and the server name is USMASQL1
the above command doesnot work
Posts: 7698 Joined: Mon Apr 23, 2012 4:28 pm
Post
by slansing » Mon May 06, 2013 2:32 pm
What do you get as output from the Nagios server's command line when running that check against the MSSQL server? Does it work with just one instance name? "USMASQL1"
maxwellmiranda
Post
by maxwellmiranda » Mon May 06, 2013 3:01 pm
i get the message " cannot connect to the sql server"
i tried with just the instance name but am getting the same error
Post
by scottwilkerson » Mon May 06, 2013 4:14 pm
If you are monitoring an instance you need to remove the -p 1433 and if you have a \ you will need to escape it
./check_mssql_database.py -H 'usmasql1.bose.com' -U 'nagios' -P 'nagios' -I USMASQL1\\USMASQL1 -T 'master' --time2connect --warning 1 --critical 5
On some servers just
./check_mssql_database.py -H 'usmasql1.bose.com' -U 'nagios' -P 'nagios' -I USMASQL1 -T 'master' --time2connect --warning 1 --critical 5
