After going through check_wmi_plus.pl code and experimenting, I was able to get it right.
Get Warning and Critical when free space drops below certain number of GB instead of percentage.
in example mentioned
5G and 4G need to be appended with colonCommand view
$USER1$/check_wmi_plus.pl -H $HOSTADDRESS$ -u $ARG1$ -p $ARG2$ -m checkdrivesize -a "$ARG3$" -w _FreeGB=$ARG4$ -c _FreeGB=$ARG5$ $ARG6$
ARG3=C|D|E|Q|H|I|L|M|N
ARG4=5G
ARG5=4G
Command view
ARG4=5G:
ARG5=4G:Code: Select all
-w '_FreeGB=5:' -c '_FreeGB=4:'according to this
EXAMPLE RANGES
This table lists example WARN/CRIT criteria and when they will trigger an alert.
10 < 0 or > 10, (outside the range of {0 .. 10})
10: < 10, (outside {10 .. infinity})
~:10 > 10, (outside the range of {-infinity .. 10})
10:20 < 10 or > 20, (outside the range of {10 .. 20})
\@10:20 = 10 and = 20, (inside the range of {10 .. 20})
10G < 0 or > 10G, (outside the range of {0 .. 10G})
