check_nrpe
nebblkshts
Re: check_nrpe
Post by nebblkshts »
I don't think long a week to install then just convert over a week-end so if I get the go ahead couple weeks to change over. as far as I have found there are only two services installed on this VM.
nebblkshts
Re: check_nrpe
I was referring to the server its self and trying to make it work in its current state.
Re: check_nrpe
If that's something you're alright with, I think that would be a sane route to take. Once posts on the forum get over the 10-page mark, we're typically at the end of what we can do in a given situation.
nebblkshts
Re: check_nrpe
Yes that will give me a better understanding as to what is going on and I can document all of that.
Re: check_nrpe
Let's do that then. For the sake of our workflow, please post back only once you either A.) have completed the install, or B.) have further questions - anything else and we will need to reply with a "Thanks, keep in touch" just to keep our dashboards clear :)
