extension=ixed.5.3.linCode: Select all
service httpd restartCode: Select all
php -q /usr/local/nagiosxi/scripts/parse_core_eventlog.php
cat /etc/php.ini |grep disable_functionsCode: Select all
[root@mon ~]# php -q /usr/local/nagiosxi/scripts/parse_core_eventlog.php
CURRENT SIZE: 0
LAST SIZE: 0
READ ALL=Yes
READ BYTES=0
CMD=cat /usr/local/nagios/var/nagios.log > /usr/local/nagiosxi/var/corelog.diff
CMD=grep 'Warning: Check result queue contained results for ' /usr/local/nagiosxi/var/corelog.diff
MATCHES=
Array
CMD=grep 'Passive check result was received for ' /usr/local/nagiosxi/var/corelog.diff
MATCHES=
Array
MISSING OBJECTS:
Array
[root@mon ~]# cat /etc/php.ini |grep disable_functions
disable_functions =Code: Select all
$log_file = grab_array_var($cfg['component_info']['nagioscore'],'log_file', '/somefolder/var/nagios.log');Code: Select all
$cfg['component_info']=array(
"nagioscore" => array(
"log_file" => "/usr/local/nagios/var/nagios.log",
