Notifications on Openfire?
Yaerox
Re: Notifications on Openfire?
Post by Yaerox »
scottwilkerson wrote:just to be sure, can you post the output of the following
ls -l /usr/local/nagios/var/rw/nagibot.fifo
linux-wnrb:~ # ls -l /usr/local/nagios/var/rw/nagibot.fifo
prw-rw---- 1 nagios nagios 0 Apr 15 14:18 /usr/local/nagios/var/rw/nagibot.fifo
Regards
abrist
Red Shirt
Post by abrist »
Any chance you could post the newest output of a verbose startup of nagibot?
Yaerox
Post by Yaerox »
Sure, but nothing changed :/
linux-wnrb:/home/MYUSER # /usr/bin/nagibot.pl -vvv -c /usr/local/nagios/etc/nagibot.conf [email protected]
nagibot 0.8.3 starting ...
using config file from commandline
Trying to connect ...
Opening fifo for reading ...
connected to XXX.X.X.XXX:5222
abrist
Red Shirt
Post by abrist »
So it connects (or at least reports that is does), but your server-side logs are bare?
Yaerox
Post by Yaerox »
For me it seems that nothing gets written into the logs :/
linux-wnrb:/home/MY_USER# tail /opt/openfire/logs/stderror.log
Server halted
linux-wnrb:/home/MY_USER# tail /opt/openfire/logs/stderr.out
linux-wnrb:/home/MY_USER# tail /opt/openfire/logs/stdoutt.log
Openfire 3.8.1 [Apr 26, 2013 8:06:12 AM]
Admin console listening at:
  http://XXX.X.X.XXX:9090
  https://XXX.X.X.XXX:9091
Missing database schema for asterisk-im. Attempting to install...
asterisk-im - Database update failed. Please manually upgrade your database.
My Nagios log only shows me two known problems on services about FTP and HTTP ...
Again, not an expert, but this makes it look like the DB isn't installed
Yaerox
Post by Yaerox »
Ohh my god, never saw this message :/
Well I chose the simple installation without any external database ... maybe i should take a look on that again and finally try a reinstall ...
Regards
Yaerox
Post by Yaerox »
I took a look on it and I dont need the asterisk-im plugin. If i disable this PlugIn my Log says:
Openfire 3.8.1 [Apr 29, 2013 8:33:06 AM]
and Nagibot do the same as before. Don't think this important for the main problem ...
abrist
Red Shirt
Post by abrist »
Just for clarification as we try to investigate your problem some more:
You are trying to get notifications to forward to an XMPP chatroom not a JID, is this correct?
In your verbose output, does XXX.X.X.XXX:5222 correspond to your openfire server or nagios server? Additionally, which does your connect string correspond to: [email protected] ?
Yaerox
Post by Yaerox »
abrist wrote:You are trying to get notifications to forward to an XMPP chatroom not a JID, is this correct?
Yes it is.
abrist wrote:In your verbose output, does XXX.X.X.XXX:5222 correspond to your openfire server or nagios server? Additionally, which does your connect string correspond to: [email protected] ?
I installed Nagios and Openfire on the same server.
Thanks for help.
Regards.
