[root@DXXXMMOM nagiosxi]# yum-config-manager --enable rpmforge
Loaded plugins: rhnplugin
This system is receiving updates from RHN Classic or RHN Satellite.
======================================================== repo: rpmforge =========================================================
[rpmforge]
bandwidth = 0
base_persistdir = /var/lib/yum/repos/x86_64/6Server
baseurl = http://apt.sw.be/redhat/el6/en/x86_64/rpmforge
cache = 0
cachedir = /var/cache/yum/x86_64/6Server/rpmforge
cost = 1000
enabled = 1
enablegroups = True
exclude =
failovermethod = priority
gpgcadir = /var/lib/yum/repos/x86_64/6Server/rpmforge/gpgcadir
gpgcakey =
gpgcheck = True
gpgdir = /var/lib/yum/repos/x86_64/6Server/rpmforge/gpgdir
gpgkey = file:///etc/pki/rpm-gpg/RPM-GPG-KEY-rpmforge-dag
hdrdir = /var/cache/yum/x86_64/6Server/rpmforge/headers
http_caching = all
includepkgs =
keepalive = True
mdpolicy = group:primary
mediaid =
metadata_expire = 21600
metalink =
mirrorlist = http://apt.sw.be/redhat/el6/en/mirrors-rpmforge
mirrorlist_expire = 86400
name = RHEL 6Server - RPMforge.net - dag
old_base_cache_dir =
password =
persistdir = /var/lib/yum/repos/x86_64/6Server/rpmforge
pkgdir = /var/cache/yum/x86_64/6Server/rpmforge/packages
proxy =
proxy_dict =
proxy_password =
proxy_username =
repo_gpgcheck = False
retries = 10
skip_if_unavailable = False
ssl_check_cert_permissions = True
sslcacert =
sslclientcert =
sslclientkey =
sslverify = True
throttle = 0
timeout = 30.0
username =
[root@DXXXMMOM nagiosxi]# pwd
/tmp/nagiosxi
[root@DXXXMMOM nagiosxi]# ./fullinstall
^[[28~========================
Nagios XI Full Installer
This script will do a complete install of Nagios XI by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a 'clean' install of CentOS or RedHat. Do NOT use this on a system that has been
tasked with other purposes or has an existing install of Nagios Core. To create such a clean install you should have selected
ONLY the 'Base' package in the OS installer.
Do you want to continue? [Y/n] Y
Installation cancelled
[=============== my log history is not big enough..... but here is the tail of install.log.... =======]
--> Processing Dependency: php-pear for package: nagiosxi-deps-2012r2.0-1.noarch
--> Processing Dependency: php-pgsql for package: nagiosxi-deps-2012r2.0-1.noarch
--> Processing Dependency: php-snmp for package: nagiosxi-deps-2012r2.0-1.noarch
--> Processing Dependency: php-xml for package: nagiosxi-deps-2012r2.0-1.noarch
--> Processing Dependency: postgresql for package: nagiosxi-deps-2012r2.0-1.noarch
--> Processing Dependency: postgresql-devel for package: nagiosxi-deps-2012r2.0-1.noarch
--> Processing Dependency: postgresql-libs for package: nagiosxi-deps-2012r2.0-1.noarch
--> Processing Dependency: postgresql-server for package: nagiosxi-deps-2012r2.0-1.noarch
--> Processing Dependency: pymssql for package: nagiosxi-deps-2012r2.0-1.noarch
--> Processing Dependency: python-lxml for package: nagiosxi-deps-2012r2.0-1.noarch
--> Processing Dependency: rpmdevtools for package: nagiosxi-deps-2012r2.0-1.noarch
--> Processing Dependency: rrdtool for package: nagiosxi-deps-2012r2.0-1.noarch
--> Processing Dependency: rrdtool-perl for package: nagiosxi-deps-2012r2.0-1.noarch
--> Processing Dependency: rrdtool-python for package: nagiosxi-deps-2012r2.0-1.noarch
---> Package php-pear-HTML-Template-IT.noarch 0:1.3.0-2.el5 will be installed
--> Running transaction check
---> Package expat-devel.x86_64 0:2.0.1-11.el6_2 will be installed
---> Package fping.x86_64 0:2.4b2-10.el6 will be installed
---> Package gd.x86_64 0:2.0.35-11.el6 will be installed
--> Processing Dependency: libXpm.so.4()(64bit) for package: gd-2.0.35-11.el6.x86_64
---> Package gd-devel.x86_64 0:2.0.35-11.el6 will be installed
--> Processing Dependency: zlib-devel for package: gd-devel-2.0.35-11.el6.x86_64
--> Processing Dependency: libpng-devel for package: gd-devel-2.0.35-11.el6.x86_64
--> Processing Dependency: libjpeg-devel for package: gd-devel-2.0.35-11.el6.x86_64
--> Processing Dependency: libXpm-devel for package: gd-devel-2.0.35-11.el6.x86_64
--> Processing Dependency: libX11-devel for package: gd-devel-2.0.35-11.el6.x86_64
--> Processing Dependency: freetype-devel for package: gd-devel-2.0.35-11.el6.x86_64
--> Processing Dependency: fontconfig-devel for package: gd-devel-2.0.35-11.el6.x86_64
---> Package graphviz.x86_64 0:2.26.0-10.el6 will be installed
--> Processing Dependency: urw-fonts for package: graphviz-2.26.0-10.el6.x86_64
--> Processing Dependency: libXt.so.6()(64bit) for package: graphviz-2.26.0-10.el6.x86_64
--> Processing Dependency: libXmu.so.6()(64bit) for package: graphviz-2.26.0-10.el6.x86_64
--> Processing Dependency: libXaw.so.7()(64bit) for package: graphviz-2.26.0-10.el6.x86_64
---> Package httpd.x86_64 0:2.2.15-28.el6_4 will be installed
--> Processing Dependency: httpd-tools = 2.2.15-28.el6_4 for package: httpd-2.2.15-28.el6_4.x86_64
--> Processing Dependency: apr-util-ldap for package: httpd-2.2.15-28.el6_4.x86_64
--> Processing Dependency: /etc/mime.types for package: httpd-2.2.15-28.el6_4.x86_64
--> Processing Dependency: libaprutil-1.so.0()(64bit) for package: httpd-2.2.15-28.el6_4.x86_64
--> Processing Dependency: libapr-1.so.0()(64bit) for package: httpd-2.2.15-28.el6_4.x86_64
---> Package libmcrypt.x86_64 0:2.5.8-9.el6 will be installed
---> Package libmcrypt-devel.x86_64 0:2.5.8-9.el6 will be installed
---> Package make.x86_64 1:3.81-20.el6 will be installed
---> Package mod_ssl.x86_64 1:2.2.15-28.el6_4 will be installed
---> Package mrtg.x86_64 0:2.16.2-7.el6 will be installed
--> Processing Dependency: mrtg-libs = 2.16.2-7.el6 for package: mrtg-2.16.2-7.el6.x86_64
--> Processing Dependency: perl-Socket6 for package: mrtg-2.16.2-7.el6.x86_64
--> Processing Dependency: perl-IO-Socket-INET6 for package: mrtg-2.16.2-7.el6.x86_64
--> Processing Dependency: perl(locales_mrtg) for package: mrtg-2.16.2-7.el6.x86_64
--> Processing Dependency: perl(MRTG_lib) for package: mrtg-2.16.2-7.el6.x86_64
---> Package mysql.x86_64 0:5.1.69-1.el6_4 will be installed
---> Package mysql-devel.x86_64 0:5.1.69-1.el6_4 will be installed
---> Package mysql-server.x86_64 0:5.1.69-1.el6_4 will be installed
--> Processing Dependency: perl-DBI for package: mysql-server-5.1.69-1.el6_4.x86_64
--> Processing Dependency: perl(DBI) for package: mysql-server-5.1.69-1.el6_4.x86_64
---> Package nagiosxi-deps.noarch 0:2012r2.0-1 will be installed
--> Processing Dependency: perl(Net::SMTP::TLS) for package: nagiosxi-deps-2012r2.0-1.noarch
---> Package net-snmp.x86_64 1:5.5-44.el6_4.1 will be installed
--> Processing Dependency: libsensors.so.4()(64bit) for package: 1:net-snmp-5.5-44.el6_4.1.x86_64
---> Package net-snmp-libs.x86_64 1:5.5-44.el6_4.1 will be installed
---> Package net-snmp-utils.x86_64 1:5.5-44.el6_4.1 will be installed
---> Package nmap.x86_64 2:5.51-2.el6 will be installed
---> Package numpy.x86_64 0:1.4.1-9.el6 will be installed
--> Processing Dependency: python-nose for package: numpy-1.4.1-9.el6.x86_64
--> Processing Dependency: libptf77blas.so.3()(64bit) for package: numpy-1.4.1-9.el6.x86_64
--> Processing Dependency: libptcblas.so.3()(64bit) for package: numpy-1.4.1-9.el6.x86_64
--> Processing Dependency: liblapack.so.3()(64bit) for package: numpy-1.4.1-9.el6.x86_64
--> Processing Dependency: libgfortran.so.3()(64bit) for package: numpy-1.4.1-9.el6.x86_64
--> Processing Dependency: libatlas.so.3()(64bit) for package: numpy-1.4.1-9.el6.x86_64
---> Package openldap-devel.x86_64 0:2.4.23-32.el6_4.1 will be installed
--> Processing Dependency: cyrus-sasl-devel >= 2.1 for package: openldap-devel-2.4.23-32.el6_4.1.x86_64
---> Package openssl-devel.x86_64 0:1.0.0-27.el6_4.2 will be installed
--> Processing Dependency: krb5-devel for package: openssl-devel-1.0.0-27.el6_4.2.x86_64
---> Package perl-CPAN.x86_64 0:1.9402-131.el6_4 will be installed
--> Processing Dependency: perl(Digest::SHA) for package: perl-CPAN-1.9402-131.el6_4.x86_64
---> Package perl-Crypt-SSLeay.x86_64 0:0.57-16.el6 will be installed
---> Package perl-DBD-MySQL.x86_64 0:4.013-3.el6 will be installed
---> Package perl-Error.noarch 1:0.17015-4.el6 will be installed
---> Package perl-Mail-IMAPClient.noarch 0:3.32-1.el6 will be installed
--> Processing Dependency: perl(Parse::RecDescent) for package: perl-Mail-IMAPClient-3.32-1.el6.noarch
---> Package perl-Mail-POP3Client.noarch 0:2.18-6.el6 will be installed
---> Package perl-Net-DNS.x86_64 0:0.65-4.el6 will be installed
--> Processing Dependency: perl(Digest::HMAC_MD5) for package: perl-Net-DNS-0.65-4.el6.x86_64
---> Package perl-Net-SNMP.noarch 0:5.2.0-4.el6 will be installed
--> Processing Dependency: perl(Digest::SHA1) for package: perl-Net-SNMP-5.2.0-4.el6.noarch
--> Processing Dependency: perl(Crypt::DES) for package: perl-Net-SNMP-5.2.0-4.el6.noarch
---> Package perl-Time-HiRes.x86_64 4:1.9721-131.el6_4 will be installed
---> Package perl-XML-Parser.x86_64 0:2.36-7.el6 will be installed
--> Processing Dependency: perl(URI::file) for package: perl-XML-Parser-2.36-7.el6.x86_64
--> Processing Dependency: perl(URI) for package: perl-XML-Parser-2.36-7.el6.x86_64
---> Package perl-XML-Simple.noarch 0:2.18-6.el6 will be installed
---> Package perl-libwww-perl.noarch 0:5.833-2.el6 will be installed
--> Processing Dependency: perl-HTML-Parser >= 3.33 for package: perl-libwww-perl-5.833-2.el6.noarch
--> Processing Dependency: perl(HTML::Entities) for package: perl-libwww-perl-5.833-2.el6.noarch
--> Processing Dependency: perl(Compress::Zlib) for package: perl-libwww-perl-5.833-2.el6.noarch
---> Package php.x86_64 0:5.3.3-22.el6 will be installed
--> Processing Dependency: php-common(x86-64) = 5.3.3-22.el6 for package: php-5.3.3-22.el6.x86_64
--> Processing Dependency: php-cli(x86-64) = 5.3.3-22.el6 for package: php-5.3.3-22.el6.x86_64
---> Package php-gd.x86_64 0:5.3.3-22.el6 will be installed
---> Package php-mcrypt.x86_64 0:5.3.3-1.el6 will be installed
---> Package php-mssql.x86_64 0:5.3.3-1.el6 will be installed
--> Processing Dependency: php-pdo >= 5.3.3 for package: php-mssql-5.3.3-1.el6.x86_64
--> Processing Dependency: libsybdb.so.5()(64bit) for package: php-mssql-5.3.3-1.el6.x86_64
---> Package php-mysql.x86_64 0:5.3.3-22.el6 will be installed
---> Package php-pear.noarch 1:1.9.4-4.el6 will be installed
---> Package php-pgsql.x86_64 0:5.3.3-22.el6 will be installed
---> Package php-snmp.x86_64 0:5.3.3-22.el6 will be installed
---> Package php-xml.x86_64 0:5.3.3-22.el6 will be installed
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.24)(64bit) for package: php-xml-5.3.3-22.el6.x86_64
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.22)(64bit) for package: php-xml-5.3.3-22.el6.x86_64
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.18)(64bit) for package: php-xml-5.3.3-22.el6.x86_64
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.13)(64bit) for package: php-xml-5.3.3-22.el6.x86_64
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.11)(64bit) for package: php-xml-5.3.3-22.el6.x86_64
--> Processing Dependency: libxslt.so.1()(64bit) for package: php-xml-5.3.3-22.el6.x86_64
--> Processing Dependency: libexslt.so.0()(64bit) for package: php-xml-5.3.3-22.el6.x86_64
---> Package postgresql.x86_64 0:8.4.13-1.el6_3 will be installed
---> Package postgresql-devel.x86_64 0:8.4.13-1.el6_3 will be installed
---> Package postgresql-libs.x86_64 0:8.4.13-1.el6_3 will be installed
---> Package postgresql-server.x86_64 0:8.4.13-1.el6_3 will be installed
---> Package pymssql.x86_64 0:1.0.2-4.el6 will be installed
---> Package python-lxml.x86_64 0:2.2.3-1.1.el6 will be installed
---> Package rpmdevtools.noarch 0:7.5-2.el6 will be installed
--> Processing Dependency: rpm-build >= 4.4.2.1 for package: rpmdevtools-7.5-2.el6.noarch
--> Processing Dependency: fakeroot for package: rpmdevtools-7.5-2.el6.noarch
---> Package rrdtool.x86_64 0:1.3.8-6.el6 will be installed
--> Processing Dependency: dejavu-sans-mono-fonts for package: rrdtool-1.3.8-6.el6.x86_64
--> Processing Dependency: dejavu-lgc-sans-mono-fonts for package: rrdtool-1.3.8-6.el6.x86_64
---> Package rrdtool-perl.x86_64 0:1.3.8-6.el6 will be installed
---> Package rrdtool-python.x86_64 0:1.3.8-6.el6 will be installed
---> Package apr.x86_64 0:1.3.9-5.el6_2 will be installed
---> Package apr-util.x86_64 0:1.3.9-3.el6_0.1 will be installed
---> Package apr-util-ldap.x86_64 0:1.3.9-3.el6_0.1 will be installed
---> Package atlas.x86_64 0:3.8.4-2.el6 will be installed
---> Package cyrus-sasl-devel.x86_64 0:2.1.23-13.el6_3.1 will be installed
---> Package dejavu-lgc-sans-mono-fonts.noarch 0:2.30-2.el6 will be installed
--> Processing Dependency: dejavu-fonts-common = 2.30-2.el6 for package: dejavu-lgc-sans-mono-fonts-2.30-2.el6.noarch
---> Package dejavu-sans-mono-fonts.noarch 0:2.30-2.el6 will be installed
---> Package fakeroot.x86_64 0:1.12.2-22.2.el6 will be installed
--> Processing Dependency: fakeroot-libs = 1.12.2-22.2.el6 for package: fakeroot-1.12.2-22.2.el6.x86_64
---> Package fontconfig-devel.x86_64 0:2.8.0-3.el6 will be installed
---> Package freetds.x86_64 0:0.91-2.el6 will be installed
--> Processing Dependency: libodbcinst.so.2()(64bit) for package: freetds-0.91-2.el6.x86_64
--> Processing Dependency: libodbc.so.2()(64bit) for package: freetds-0.91-2.el6.x86_64
---> Package freetype-devel.x86_64 0:2.3.11-14.el6_3.1 will be installed
---> Package httpd-tools.x86_64 0:2.2.15-28.el6_4 will be installed
---> Package krb5-devel.x86_64 0:1.10.3-10.el6_4.2 will be installed
--> Processing Dependency: libselinux-devel for package: krb5-devel-1.10.3-10.el6_4.2.x86_64
--> Processing Dependency: libcom_err-devel for package: krb5-devel-1.10.3-10.el6_4.2.x86_64
--> Processing Dependency: keyutils-libs-devel for package: krb5-devel-1.10.3-10.el6_4.2.x86_64
---> Package libX11-devel.x86_64 0:1.5.0-4.el6 will be installed
--> Processing Dependency: pkgconfig(xcb) >= 1.1.92 for package: libX11-devel-1.5.0-4.el6.x86_64
--> Processing Dependency: pkgconfig(xproto) for package: libX11-devel-1.5.0-4.el6.x86_64
--> Processing Dependency: pkgconfig(xcb) for package: libX11-devel-1.5.0-4.el6.x86_64
--> Processing Dependency: pkgconfig(kbproto) for package: libX11-devel-1.5.0-4.el6.x86_64
---> Package libXaw.x86_64 0:1.0.11-2.el6 will be installed
---> Package libXmu.x86_64 0:1.1.1-2.el6 will be installed
---> Package libXpm.x86_64 0:3.5.10-2.el6 will be installed
---> Package libXpm-devel.x86_64 0:3.5.10-2.el6 will be installed
---> Package libXt.x86_64 0:1.1.3-1.el6 will be installed
---> Package libgfortran.x86_64 0:4.4.7-3.el6 will be installed
---> Package libjpeg-turbo-devel.x86_64 0:1.2.1-1.el6 will be installed
---> Package libpng-devel.x86_64 2:1.2.49-1.el6_2 will be installed
---> Package libxslt.x86_64 0:1.1.26-2.el6_3.1 will be installed
---> Package lm_sensors-libs.x86_64 0:3.1.1-17.el6 will be installed
---> Package mailcap.noarch 0:2.1.31-2.el6 will be installed
---> Package mrtg-libs.x86_64 0:2.16.2-7.el6 will be installed
--> Processing Dependency: perl(SNMP_Session) for package: mrtg-libs-2.16.2-7.el6.x86_64
--> Processing Dependency: perl(BER) for package: mrtg-libs-2.16.2-7.el6.x86_64
---> Package perl-Compress-Zlib.x86_64 0:2.020-131.el6_4 will be installed
--> Processing Dependency: perl(IO::Uncompress::Gunzip) >= 2.020 for package: perl-Compress-Zlib-2.020-131.el6_4.x86_64
--> Processing Dependency: perl(IO::Compress::Gzip::Constants) >= 2.020 for package: perl-Compress-Zlib-2.020-131.el6_4.x86_64
--> Processing Dependency: perl(IO::Compress::Gzip) >= 2.020 for package: perl-Compress-Zlib-2.020-131.el6_4.x86_64
--> Processing Dependency: perl(IO::Compress::Base::Common) >= 2.020 for package: perl-Compress-Zlib-2.020-131.el6_4.x86_64
---> Package perl-Crypt-DES.x86_64 0:2.05-9.el6 will be installed
---> Package perl-DBI.x86_64 0:1.609-4.el6 will be installed
---> Package perl-Digest-HMAC.noarch 0:1.01-22.el6 will be installed
---> Package perl-Digest-SHA.x86_64 1:5.47-131.el6_4 will be installed
---> Package perl-Digest-SHA1.x86_64 0:2.12-2.el6 will be installed
---> Package perl-HTML-Parser.x86_64 0:3.64-2.el6 will be installed
--> Processing Dependency: perl(HTML::Tagset) >= 3.03 for package: perl-HTML-Parser-3.64-2.el6.x86_64
--> Processing Dependency: perl(HTML::Tagset) for package: perl-HTML-Parser-3.64-2.el6.x86_64
---> Package perl-IO-Socket-INET6.noarch 0:2.56-4.el6 will be installed
---> Package perl-Parse-RecDescent.noarch 0:1.965-1.el6 will be installed
---> Package perl-Socket6.x86_64 0:0.23-3.el6 will be installed
---> Package perl-URI.noarch 0:1.40-2.el6 will be installed
---> Package php-cli.x86_64 0:5.3.3-22.el6 will be installed
---> Package php-common.x86_64 0:5.3.3-22.el6 will be installed
---> Package php-pdo.x86_64 0:5.3.3-22.el6 will be installed
---> Package python-nose.noarch 0:0.10.4-3.1.el6 will be installed
--> Processing Dependency: python-setuptools for package: python-nose-0.10.4-3.1.el6.noarch
---> Package rpm-build.x86_64 0:4.8.0-32.el6 will be installed
--> Processing Dependency: patch >= 2.5 for package: rpm-build-4.8.0-32.el6.x86_64
--> Processing Dependency: /usr/bin/gdb-add-index for package: rpm-build-4.8.0-32.el6.x86_64
---> Package urw-fonts.noarch 0:2.4-10.el6 will be installed
---> Package zlib-devel.x86_64 0:1.2.3-29.el6 will be installed
---> Package dejavu-fonts-common.noarch 0:2.30-2.el6 will be installed
--> Processing Dependency: fontpackages-filesystem for package: dejavu-fonts-common-2.30-2.el6.noarch
---> Package fakeroot-libs.x86_64 0:1.12.2-22.2.el6 will be installed
---> Package gdb.x86_64 0:7.2-60.el6_4.1 will be installed
---> Package keyutils-libs-devel.x86_64 0:1.4-4.el6 will be installed
---> Package libcom_err-devel.x86_64 0:1.41.12-14.el6 will be installed
---> Package libselinux-devel.x86_64 0:2.0.94-5.3.el6_4.1 will be installed
--> Processing Dependency: libsepol-devel >= 2.0.32-1 for package: libselinux-devel-2.0.94-5.3.el6_4.1.x86_64
--> Processing Dependency: pkgconfig(libsepol) for package: libselinux-devel-2.0.94-5.3.el6_4.1.x86_64
---> Package libxcb-devel.x86_64 0:1.8.1-1.el6 will be installed
--> Processing Dependency: pkgconfig(xau) >= 0.99.2 for package: libxcb-devel-1.8.1-1.el6.x86_64
---> Package patch.x86_64 0:2.6-6.el6 will be installed
---> Package perl-HTML-Tagset.noarch 0:3.20-4.el6 will be installed
---> Package perl-IO-Compress-Base.x86_64 0:2.020-131.el6_4 will be installed
---> Package perl-IO-Compress-Zlib.x86_64 0:2.020-131.el6_4 will be installed
---> Package perl-SNMP_Session.noarch 0:1.12-4.el6 will be installed
---> Package python-setuptools.noarch 0:0.6.10-3.el6 will be installed
---> Package unixODBC.x86_64 0:2.2.14-12.el6_3 will be installed
--> Processing Dependency: libltdl.so.7()(64bit) for package: unixODBC-2.2.14-12.el6_3.x86_64
---> Package xorg-x11-proto-devel.noarch 0:7.6-25.el6 will be installed
---> Package fontpackages-filesystem.noarch 0:1.41-1.1.el6 will be installed
---> Package libXau-devel.x86_64 0:1.0.6-4.el6 will be installed
---> Package libsepol-devel.x86_64 0:2.0.41-4.el6 will be installed
---> Package libtool-ltdl.x86_64 0:2.2.6-15.5.el6 will be installed
Error: Package: nagiosxi-deps-2012r2.0-1.noarch (/nagiosxi-deps-2012r2.0-1.noarch)
Requires: perl(Net::SMTP::TLS)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
