Your request was not processed in a timely manner...
Re: Your request was not processed in a timely manner...
Post by slansing »
We are tracking this issue with a number of users, please submit a ticket to [email protected].
GldRush98
Post by GldRush98 »
I can't open a ticket apparently. My email address is no longer tied to our license or something (we did change our email address scheme at work a while back, so that could be why, not sure...).
I see there are now a couple other threads all experiencing the same issues as me.
Again, I am noticing a common factor between all of these systems is that they use SSL for Nagios web access. I have a good feeling that this issue is directly tied to the systems using SSL.
I have tried re-enabling standard http access, but that doesn't seem to resolve the issue.
Prod XI: Debian 12 - Nagios XI 2026R1.2
Dev XI: Debian 12 - Nagios XI 2026R1.2
abrist
Red Shirt
Post by abrist »
I have an ssl enabled test box that upgraded cleanly to 2012r2.1. I don't think that is the issue, but we have been trying to move these clients into remote sessions so we can collect more information about the problem.
As far as your registered email account issues go, send an email to [email protected] and they will get your account taken care of. Afterwards, open a ticket through [email protected] and we will move to a remote session.
GldRush98
Post by GldRush98 »
Ok, I have emailed the sales address.
Yeah, I did a similar test. I uploaded an OVF template 1.8, enabled SSL and did the upgrade and everything still works after the upgrade. :(
Post by slansing »
Everything works? Or it is still not working properly? Can you share the output of these commands:
cd /usr/local/nagiosxi
ls -ld ./ cron html html/includes
ll html/config.inc.php
ll html/includes/utils.inc.php
GldRush98
Post by GldRush98 »
No, my production box is still "broke". (I was referring to a test vmware box I played with earlier trying to reproduce the issue)
[root@nagios nagiosxi]# ls -ld ./ cron html html/includes
drwxr-xr-x 10 nagios nagios 4096 Jun  5  2012 ./
drwxr-xr-x  2 nagios nagios 4096 Aug 22  2012 cron
drwxr-xr-x 20 nagios nagios 4096 Jan 30 14:34 html
drwxr-x--- 11 nagios nagios 4096 Oct 10  2012 html/includes
[root@nagios nagiosxi]# ll html/config.inc.php
-rwxr-x--- 1 nagios nagios 7690 May 28 10:33 html/config.inc.php
[root@nagios nagiosxi]# ll html/includes/utils.inc.php
-rwxr-x--- 1 nagios nagios 26681 May 28 10:33 html/includes/utils.inc.php
p.s. I should have access to the ticket system within an hour, so I'll get an official ticket opened up later this afternoon as long as I don't get too busy at work.
Can you run the following and output any errors you receive
su nagios -c '/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php'
Last edited by scottwilkerson on Mon Jun 03, 2013 4:20 pm, edited 1 time in total.
Reason: changed command
GldRush98
Post by GldRush98 »
[root@nagios nagiosxi]# su nagios -c '/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php'
PROCESSED 0 COMMANDS
weird..
echo "select count(*) from xi_commands;"|psql nagiosxi nagiosxi
echo "select * from xi_commands order by command_id DESC;"|psql nagiosxi nagiosxi
GldRush98
Post by GldRush98 »
[root@nagios nagiosxi]# echo "select count(*) from xi_commands;"|psql nagiosxi nagiosxi
 count
    15
(1 row)
[root@nagios nagiosxi]# echo "select * from xi_commands order by command_id DESC;"|psql nagiosxi nagiosxi
 command_id | group_id | submitter_id | beneficiary_id | command |      submission_time       |         event_time         | frequency_type | frequency_units | frequency_interval |      processing_time       | status_code | result_code |                                                               command_data        |      result
       2005 |        0 |           49 |              0 |    1100 | 2013-06-03 11:32:59.077276 | 2013-06-03 11:32:59.077276 |              0 |               0 |                  0 | 2013-06-03 11:32:59.318609 |           2 |           0 | a:2:{s:8:"username";s:11:"x";s:8:"password";s:8:"x";}        |
       2004 |        0 |           49 |              0 |    1100 | 2013-06-03 11:30:34.021436 | 2013-06-03 11:30:34.021436 |              0 |               0 |                  0 | 2013-06-03 11:30:34.139355 |           2 |           0 | a:2:{s:8:"username";s:11:"x";s:8:"password";s:8:"x";}        |
       2003 |        0 |           49 |              0 |      16 | 2013-06-03 11:22:21.398252 | 2013-06-03 11:22:21.398252 |              0 |               0 |                  0 | 2013-06-03 11:22:21.590512 |           2 |           0 | a:4:{s:9:"host_name";s:18:"x VPN";s:12:"service_name";s:16:"SIP Registration";s:3:"cmd";i:7;s:10:"start_time";i:1370276531;}              | Command submitted
       2002 |        0 |           49 |              0 |      16 | 2013-06-03 11:22:13.698864 | 2013-06-03 11:22:13.698864 |              0 |               0 |                  0 | 2013-06-03 11:22:14.528584 |           2 |           0 | a:3:{s:9:"host_name";s:18:"x VPN";s:12:"service_name";s:16:"SIP Registration";s:3:"cmd";i:22;}                                            | Command submitted
       2001 |        0 |           49 |              0 |      16 | 2013-06-03 10:31:45.869914 | 2013-06-03 10:31:45.869914 |              0 |               0 |                  0 | 2013-06-03 10:31:46.442432 |           2 |           0 | a:3:{s:9:"host_name";s:18:"x VPN";s:12:"service_name";s:16:"SIP Registration";s:3:"cmd";i:23;}                                            | Command submitted
       2000 |        0 |           49 |              0 |      16 | 2013-06-03 09:53:50.967563 | 2013-06-03 09:53:50.967563 |              0 |               0 |                  0 | 2013-06-03 09:53:51.54242  |           2 |           0 | a:2:{s:3:"cmd";i:4;s:10:"comment_id";i:1198;}        | Command submitted
       1999 |        0 |           49 |              0 |      16 | 2013-06-03 09:53:44.379785 | 2013-06-03 09:53:44.379785 |              0 |               0 |                  0 | 2013-06-03 09:53:45.806943 |           2 |           0 | a:2:{s:3:"cmd";i:4;s:10:"comment_id";i:1199;}        | Command submitted
       1998 |        0 |           49 |              0 |      16 | 2013-06-03 09:53:44.153359 | 2013-06-03 09:53:44.153359 |              0 |               0 |                  0 | 2013-06-03 09:53:45.750424 |           2 |           0 | a:2:{s:3:"cmd";i:4;s:10:"comment_id";i:1200;}        | Command submitted
       1997 |        0 |           49 |              0 |      16 | 2013-06-03 09:53:44.099012 | 2013-06-03 09:53:44.099012 |              0 |               0 |                  0 | 2013-06-03 09:53:45.692164 |           2 |           0 | a:2:{s:3:"cmd";i:4;s:10:"comment_id";i:1201;}        | Command submitted
       1996 |        0 |           49 |              0 |      16 | 2013-06-03 09:53:42.465222 | 2013-06-03 09:53:42.465222 |              0 |               0 |                  0 | 2013-06-03 09:53:42.929213 |           2 |           0 | a:2:{s:3:"cmd";i:4;s:10:"comment_id";i:1202;}        | Command submitted
       1995 |        0 |           49 |              0 |      16 | 2013-06-03 09:53:39.876467 | 2013-06-03 09:53:39.876467 |              0 |               0 |                  0 | 2013-06-03 09:53:40.289177 |           2 |           0 | a:2:{s:3:"cmd";i:4;s:10:"comment_id";i:1197;}        | Command submitted
       1994 |        0 |           49 |              0 |      16 | 2013-06-03 09:53:29.887873 | 2013-06-03 09:53:29.887873 |              0 |               0 |                  0 | 2013-06-03 09:53:31.236409 |           2 |           0 | a:2:{s:3:"cmd";i:4;s:10:"comment_id";i:1196;}        | Command submitted
       1993 |        0 |           49 |              0 |      16 | 2013-06-03 09:53:20.034528 | 2013-06-03 09:53:20.034528 |              0 |               0 |                  0 | 2013-06-03 09:53:21.308185 |           2 |           0 | a:2:{s:3:"cmd";i:4;s:10:"comment_id";i:1195;}        | Command submitted
       1992 |        0 |           49 |              0 |      16 | 2013-06-03 09:52:42.522186 | 2013-06-03 09:52:42.522186 |              0 |               0 |                  0 | 2013-06-03 09:52:43.160646 |           2 |           0 | a:4:{s:9:"host_name";s:18:"x VPN";s:12:"service_name";s:16:"SIP Registration";s:3:"cmd";i:7;s:10:"start_time";i:1370271159;}              | Command submitted
       1991 |        0 |           49 |              0 |      16 | 2013-06-03 08:53:46.013611 | 2013-06-03 08:53:46.013611 |              0 |               0 |                  0 | 2013-06-03 08:53:46.438441 |           2 |           0 | a:4:{s:9:"host_name";s:18:"x VPN";s:12:"service_name";s:12:"Current Load";s:3:"cmd";i:7;s:10:"start_time";i:1370267623;}                  | Command submitted
(15 rows)
