Linux SNMP: Process name table No response from remote host
msbensonstk
Re: Linux SNMP: Process name table No response from remote h
We are having this problem on about 10% of our systems. The rest it works just fine, so I don't believe the plug-in is completely to blame. If we could get the plug-in to respect the extended timeout values I am fairly confident that would fix the issue, but as I demonstrated earlier in the ticket, that part of the script appears to not be working correctly.
sreinhardt
- -fno-stack-protector
On the note of those 10% systems, are they on a separate vlan, another datacenter/location, or anything else of that nature that would introduce latency. Also is this a continual issue with all of those systems or just sporadic? I would tend to agree that the timeout symptoms seem to fit your issue, I will see about that portion of the code and how the flag is handled.
msbensonstk
They are in the same VLAN and security zone (and physical switches) as the rest of the servers that are working normally. There is no difference between them security-wise or latency-wise.
The issue on them is sporadic, but down is the 'normal' state. They sporadicly are successful, but never twice in a row.
Have you tried changing the timeout directly in the script?
At line #60, change:
To:
my $o_timeout= 5; # Default 5s TimeoutCode: Select all
my $o_timeout= 20; # Default 5s TimeoutFormer Nagios employee
msbensonstk
Setting the timeout in the script appears to have no effect either:
vim /usr/local/nagios/libexec/check_snmp_process_wizard.pl
my $o_timeout = 50
date; /usr/local/nagios/libexec/check_snmp_process_wizard.pl -H <host> --login=nagiosxi --passwd=<pass> --privpass=<pass> --protocols=sha,aes -n '/usr/local/contego/ContegoSPOP/' -f -w '0,1' -c '0,1'; date
Tue Oct 15 10:08:29 CDT 2013
ERROR: Alarm signal (Nagios time-out)
Tue Oct 15 10:08:44 CDT 2013
Script still stopping after 15 seconds.
my $o_timeout = 50
Out of curiosity, have you attempted to run the check without the fullpath?
Is ContegoSPOP the actual process name you wish to monitor?
date; /usr/local/nagios/libexec/check_snmp_process_wizard.pl -H <host> --login=nagiosxi --passwd=<pass> --privpass=<pass> --protocols=sha,aes -n 'ContegoSPOP' -w '0,1' -c '0,1'; dateFormer Nagios employee
msbensonstk
Yes. It's the process name as reported by the process table (this is the same check that works on other systems).
Did the command work without the full path switch?
msbensonstk
Sorry, you'll have to clarify that a bit. Can you write out the command with the 'switch' you are referring to?
sreinhardt
your -n flag is always "-n '/usr/local/contego/ContegoSPOP/'" abrist was asking if you could run it successfully without the full path, like such:
date; /usr/local/nagios/libexec/check_snmp_process_wizard.pl -H <host> --login=nagiosxi --passwd=<pass> --privpass=<pass> --protocols=sha,aes -n 'ContegoSPOP' -w '0,1' -c '0,1'; dateNagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
