Or are you stating to use the following in the NRDS configuration? Create only one NRDS configuration?
command[Check SNMP Load]=/usr/local/nagios/libexec/check_snmp_load.pl -H $HOSTADDRESS$ -C $ARG1$ -w $ARG2$ -c $ARG3$ -T netsl -f
command[Check SNMP Memory]=/usr/local/nagios/libexec/check_snmp_mem_mrv.pl -H $HOSTADDRESS$ -C $ARG1$ -w $ARG2$ -c $ARG3$ -f
Then add a new Service in CCM for each switch and put in the args for scripts?
Views-Service Details shows netsnmp error for all devices
sreinhardt
- -fno-stack-protector
Re: Views-Service Details shows netsnmp error for all device
You are correct, I would suggest against using this via nsca, as there is not a real need to add the complexity to it at this point. As for command and service definitions in XI. I would suggest this document http://assets.nagios.com/downloads/nagi ... ios_XI.pdf
Thanks. That doc helped a lot. Now if I cause one switch to be unreachable it does not affect other switches.
sreinhardt
You are welcome, and that is great that it's responding correctly! Are you all set for this particular task then?
