For hosts: Return code of 126 is out of bounds - plugin may be missing
For services: Return code of 127 is out of bounds - plugin may be missing
For the hosts, the check is 'check_icmp' and appears to have the same permissions on both servers (live & test):
-r-sr-xr-x 1 root root 155406 Jun 11 10:43 check_icmp
When I run the test from the CCM and from the command line I get no return but when I run it from the command line I get an indication that I need to recompile the plug-ins. I realized that perhaps I hadn't run the script to update the components for the 32-bit system I'm running on now (compared to the 64-bit I copied the data from). I went back to the 'Backing up and restoring' document and followed the section under 'Things to Consider'. Upon running the ./A-subcomponents script, I get the following:
NOTE: If prompted, enter the MySQL root password
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
ERROR: Subcomponent 'ndoutils' installation failed - exiting.
Subcomponents installation failed - exiting
Where can I change where this script is lookingf ro the DB?
