NRPE Check Differeneces
jdev
Re: NRPE Check Differeneces
Post by jdev »
Correct.
Just double checked both my 64bit and 32bit systems. There's plenty of other stuff in syslog, just nothing about nagios/nrpe.
abrist
Red Shirt
Post by abrist »
It really should be logging, is syslog/syslog-ng/rsyslog installed? If so, there is a good chance that the daemon is not running correctly.
jdev
Post by jdev »
Yes, rsyslog is installed, and working, as other events are showing up in logs. I tailed the log overnight and nothing shows up for nagios or nrpe.
Try changing the following line in the nrpe.cfg on the client from this:
command[check_init_service]=/usr/lib/nagios/plugins/check_init_service $ARG1$
to this:
command[check_init_service]=sudo /usr/lib/nagios/plugins/check_init_service $ARG1$
Restart NRPE and try your check again. Did this fix the issue?
jdev
Post by jdev »
lmiltchev wrote:Try changing the following line in the nrpe.cfg on the client from this:
to this:
I had a couple other things come up that I had to resolve, so, I wasn't able to get to this at the end of last week.
I had to clone the 64bit VM this morning and I was able to add it to nagios monitoring without issue, and ALL monitors are working on the CLONE without intervention on my end (including making the change you suggested here)
abrist
Red Shirt
Post by abrist »
... so it is working now?
jdev
Post by jdev »
abrist wrote:... so it is working now?
No. Inexplicably I might add. Server1 still isn't working properly. Server2, which was cloned (in vmware) from Server1 several hours ago, is working without issue.
[edit 1232]
On a whim, I removed this host from nagios and removed the nagios-agent and associated packages from the host and re-installed nagios-agent and re-added to nagios. Still the same "NRPE: Unable to read output" error on SSH, Cron and syslog checks.
abrist
Red Shirt
Post by abrist »
Is this an eval copu of XI, or are you a customer? If you are a customer, send an email to [email protected] and we can try to move to a remote session, as this question has pretty much exhausted what we an do through the forums.
jdev
Post by jdev »
abrist wrote:Is this an eval copu of XI, or are you a customer? If you are a customer, send an email to [email protected] and we can try to move to a remote session, as this question has pretty much exhausted what we an do through the forums.
I am a customer, but, no need to email in.
I rebooted the server this morning, that fixed the issue.
All clear to close this one up then?
