Nagios Map
Re: Nagios Map
Its interesting that I get Nagios 4.0.0 in the map view and you get Nagios 4.0.2.What do you think should be my next move?
sreinhardt
- -fno-stack-protector
Re: Nagios Map
What make commands did you use when "make"-ing 4.0.2?
Re: Nagios Map
/etc/init.d/nagios stop
./configure --with-command-group=nagcmd
make all
make install
/etc/init.d/nagios start
make all
make install
sreinhardt
Re: Nagios Map
you could also try "make install-webconf" just to be 100% sure that you are getting the new versions.
Re: Nagios Map
I tried make install-webconf but still no good
Any other suggestions?
Re: Nagios Map
Every link on the left hand side (Hosts, services, host groups etc) shows:
Current Network Status
Last Updated: Wed Dec 18 11:42:28 GMT 2013
Updated every 90 seconds
Nagios® Core™ 4.0.2 - www.nagios.org
Logged in as nagiosadmin
Except Maps which shows:
Network Map For All Hosts
Last Updated: Wed Dec 18 11:43:30 GMT 2013
Nagios® Core™ 4.0.0 - www.nagios.org
View Status Detail For All Hosts
View Status Overview For All Hosts
Re: Nagios Map
After you upgraded to core 4.0.2, did you run:
cd /path/to/nagios/source
make install-cgis
service httpd restartFormer Nagios employee
Re: Nagios Map
No - Should I give this a shot?
Re: Nagios Map
Go for it. That is what updated my core test box cgis to the newest versions.
Re: Nagios Map
Also - What is the path to nagios source?
