waiting for configuration verification...... never ends.
Re: waiting for configuration verification...... never ends.
Are you using https?
Have you changed any of the database credentials?
yjchennagios
No, I only use http.
Did not change any thing on database credential.
Run the following two commands and post the output:
ll -d /usr/local/nagiosxi/scripts
ll /usr/local/nagiosxi/scriptsBe sure to check out our Knowledgebase for helpful articles and solutions!
yjchennagios
[root@itmon scripts]# ll -d /usr/local/nagiosxi/scripts
drwxr-xr-x. 2 nagios nagios 4096 Dec 12 15:06 /usr/local/nagiosxi/scripts
[root@itmon scripts]# ll /usr/local/nagiosxi/scripts
total 524
-rwxr-x---. 1 nagios nagios 4217 Dec 10 14:25 backup_xi.sh
-rw-r--r-- 1 root root 24400 Dec 12 18:57 cmd.txt
-rw-r--r-- 1 root root 1775 Dec 12 15:05 cmd.txt.old
-rw-r-----. 1 nagios nagios 2507 Dec 10 14:25 contact_notification_handler.php
-rwxr-x---. 1 nagios nagios 649 Dec 10 14:25 export_nagiosql.sh
-rwxr-x---. 1 nagios nagios 821 Dec 10 14:25 handle_nagioscore_event.php
-rwxr-x---. 1 nagios nagios 829 Dec 10 14:25 handle_nagioscore_notification.php
-rwxr-x---. 1 nagios nagios 429 Dec 10 14:25 import_nagiosql.sh
-rwxr-x---. 1 nagios nagios 149 Dec 10 14:25 kill_rrdtool.sh
-rw-r--r-- 1 root root 153 Dec 12 14:52 nagiosql.cookies
-rw-r-----. 1 nagios nagios 272368 Dec 10 14:25 nagiosql_defaults.sql
-rwxr-x---. 1 nagios nagios 970 Dec 10 14:25 nagiosql_delete_contact.php
-rwxr-x---. 1 nagios nagios 2010 Dec 10 14:25 nagiosql_delete_host.php
-rwxr-x---. 1 nagios nagios 505 Dec 10 14:25 nagiosql_delete_object.sh
-rwxr-x---. 1 nagios nagios 2867 Dec 10 14:25 nagiosql_delete_service.php
-rwxr-x---. 1 nagios nagios 993 Dec 10 14:25 nagiosql_delete_timeperiod.php
-rw-r--r-- 1 root root 7400 Dec 12 14:52 nagiosql.export.additional
-rwxr-x---. 1 nagios nagios 1637 Dec 10 14:25 nagiosql_exportall.php
-rw-r--r-- 1 root root 7096 Dec 12 14:52 nagiosql.export.monitoring
-rwxr-x---. 1 nagios nagios 1323 Dec 10 14:25 nagiosql_importall.php
-rw-r--r-- 1 root root 12483 Dec 12 14:52 nagiosql.import.monitoring
-rw-r--r-- 1 root root 5286 Dec 12 14:52 nagiosql.login
-rwxr-x---. 1 nagios nagios 1847 Dec 10 14:25 nagiosql_login.php
-rwxr-x---. 1 nagios nagios 2246 Dec 10 14:25 nagiosql_snapshot.sh
-rwxr-x---. 1 nagios nagios 258 Dec 10 14:25 nagiosql_trim_backups.sh
-rwxr-x---. 1 nagios nagios 515 Dec 10 14:25 nom_create_nagioscore_checkpoint_cond.sh
-rwxr-x---. 1 nagios nagios 826 Dec 10 14:25 nom_create_nagioscore_checkpoint.sh
-rwxr-x---. 1 nagios nagios 632 Dec 10 14:25 nom_create_nagioscore_errorpoint.sh
-rwxr-x---. 1 nagios nagios 784 Dec 10 14:25 nom_restore_nagioscore_checkpoint.sh
-rwxr-x---. 1 nagios nagios 839 Dec 10 14:25 nom_restore_nagioscore_checkpoint_specific.sh
-rwxr-x---. 1 nagios nagios 2972 Dec 10 14:25 nom_trim_nagioscore_checkpoints.sh
-rwxr-x---. 1 nagios nagios 4592 Dec 10 14:25 parse_core_eventlog.php
-rwxr-x---. 1 nagios nagios 6074 Dec 10 14:25 patch_ndoutils.php
-rw-r--r-- 1 root root 11581 Dec 12 14:52 reconfig.txt
-rwxr-x---. 1 nagios nagios 597 Dec 10 14:25 reconfigure_nagios.sh
-rwxr-x---. 1 nagios nagios 1037 Dec 10 14:25 repairmysql.sh
-rwsr-xr-x. 1 root nagios 6846 Dec 10 14:25 reset_config_perms
-rw-r-----. 1 nagios nagios 280 Dec 10 14:25 reset_config_perms.c
-rwsr-xr-x. 1 root nagios 1187 Dec 10 14:25 reset_config_perms.sh
-rwxr-x---. 1 nagios nagios 1155 Dec 10 14:25 reset_nagiosadmin_password.php
-rwxr-x---. 1 nagios nagios 964 Dec 10 14:25 restart_nagios_with_export.sh
-rwxr-x---. 1 nagios nagios 765 Dec 10 14:25 restore_defaults.sh
-rwxr-x---. 1 nagios nagios 5342 Dec 10 14:25 restore_xi.sh
-rwxr-x---. 1 nagios nagios 1847 Dec 10 14:25 send_to_auditlog.php
-rw-r-----. 1 nagios nagios 2379 Dec 10 14:25 uninstall_xi.sh
-rwxr-x---. 1 nagios nagios 321 Dec 10 14:25 upgrade_to_latest.sh
total 524
yjchennagios
Weird. I just saw the host appearing in Nagios console view now after reset command. The one I had problem on adding it by applying configuration. Why? Should I try adding another host to see if same problem happens? Or need to check a few more things before doing so?
So now it's working? Did you do anything else over the weekend?yjchennagios wrote:Why?
Add another host and check back with us with your results.yjchennagios wrote:Should I try adding another host to see if same problem happens? Or need to check a few more things before doing so?
yjchennagios
I just tested again adding one host, and got the error right away.
Waiting for configuration verification....
Backend login to the Core Config Manager failed.
The host obviously was not added in successfully. Please help.
Jenny
Jenny
Run the following commands in terminal:
If this doesn't solve your issue, go to: Admin->Reset Security Credentials, and click on "Update Credentials", without changing anything else on this page.
chown nagios:nagios nagiosql*Be sure to check out our Knowledgebase for helpful articles and solutions!
yjchennagios
I just added one windows 2008 server and one Centos system to be monitored hosts successfully. Thank you. However, the windows 2008 server's monitored services/items have the status showning "cannot fetch the information from server" warning, so no status info for these items. These items are disk usage, memory usage and UPtime. Only ping has the response with currect status info.
Another question is for Ubuntu system, can I install the same nrpe agent with Centos/RedHat on it to make it working?
Please advice. Thank you.
Jenny
Jenny
This is a whole different issue. Did you install the agent on the remote server and open ports 12489 and 5666?"cannot fetch the information from server"
