vmware swap file error
sheetzdw
Re: vmware swap file error
Post by sheetzdw »
root@NagiosCore:/home/dsdsheetz# chown -R nagios:nagcmd /usr/local/nagios/var/spool/checkresults
root@NagiosCore:/home/dsdsheetz# ls -ldva /usr/local/nagios/var/spool/checkresults
drwxrwxr-x 2 nagios nagcmd 69632 2014-02-20 13:12 /usr/local/nagios/var/spool/checkresults
root@NagiosCore:/home/dsdsheetz# grep -i 'nag' /etc/passwd
list:x:38:38:Mailing List Manager:/var/list:/bin/sh
nagios:x:107:118::/var/lib/nagios:/bin/false
config results
Nagios Core 3.3.1
Last Modified: 07-25-2011
License: GPL
Reading configuration data...
   Read main config file okay...
Processing object config directory '/usr/local/nagios/global'...
Processing object config file '/usr/local/nagios/global/host_templates.cfg'...
Processing object config file '/usr/local/nagios/global/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/global/service_templates.cfg'...
Processing object config file '/usr/local/nagios/global/hostescalation.cfg'...
Processing object config file '/usr/local/nagios/global/contacts.cfg'...
Processing object config file '/usr/local/nagios/global/misccommands.cfg'...
Processing object config file '/usr/local/nagios/global/checkcommands.cfg'...
Processing object config file '/usr/local/nagios/global/timeperiods.cfg'...
Processing object config directory '/usr/local/nagios/Default_collector'...
Processing object config file '/usr/local/nagios/Default_collector/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/Default_collector/hosts.cfg'...
Processing object config file '/usr/local/nagios/Default_collector/services.cfg'...
Processing object config file '/usr/local/nagios/Default_collector/advanced_services.cfg'...
Processing object config file '/usr/local/nagios/Default_collector/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/Default_collector/service_dependencies.cfg'...
Processing object config file '/usr/local/nagios/Default_collector/host_dependencies.cfg'...
Warning: Duplicate definition found for service 'Current Load' on host 'NagiosCore' (config file '/usr/local/nagios/Default_collector/services.cfg', starting on line 12)
Warning: Duplicate definition found for service 'NSClient++ Version' on host 'dsv-ex4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 84)
Warning: Duplicate definition found for service 'NSClient++ Version' on host 'dsv-ex2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 84)
Warning: Duplicate definition found for service 'CPU Load' on host 'dsv-ia2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 101)
Warning: Duplicate definition found for service 'CPU Load' on host 'dsv-ex4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 101)
Warning: Duplicate definition found for service 'CPU Load' on host 'dsv-ex2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 101)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'dsv-ws7' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'dsv-ia2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'ds-nt32' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'ds-nt27' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'test-ft1' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'dsv-ad1' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'dsv-ad4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'dev-ws' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'dev-ft1' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'test-ws' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'ds_nt7' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'ds_nt17' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'ds_nt16' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'ds-fs20' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'dsv-ex4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'dsv-vmm' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'dsv-ex2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'ds-msvs4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'test-td1' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 116)
Warning: Duplicate definition found for service 'Vipre Service' on host 'dsv-ex4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 131)
Warning: Duplicate definition found for service 'Vipre Service' on host 'dsv-ex2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 131)
Warning: Duplicate definition found for service 'NRPE CPU Load' on host 'DSV-Tomcat1' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 141)
Warning: Duplicate definition found for service 'DHCP Client' on host 'dsv-ex4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 265)
Warning: Duplicate definition found for service 'DHCP Client' on host 'dsv-ex2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 265)
Warning: Duplicate definition found for service 'DNS Client' on host 'dsv-ex4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 285)
Warning: Duplicate definition found for service 'DNS Client' on host 'dsv-ex2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 285)
Warning: Duplicate definition found for service 'Netlogon' on host 'dsv-ex4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 335)
Warning: Duplicate definition found for service 'Netlogon' on host 'dsv-ex2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 335)
Warning: Duplicate definition found for service 'Print Spooler' on host 'dsv-ex4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 345)
Warning: Duplicate definition found for service 'Print Spooler' on host 'dsv-ex2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 345)
Warning: Duplicate definition found for service 'RPC' on host 'dsv-ex4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 355)
Warning: Duplicate definition found for service 'RPC' on host 'dsv-ex2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 355)
Warning: Duplicate definition found for service 'Vipre Recovery Service' on host 'dsv-ex4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 365)
Warning: Duplicate definition found for service 'Vipre Recovery Service' on host 'dsv-ex2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 365)
Warning: Duplicate definition found for service 'Server Service' on host 'dsv-ex4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 373)
Warning: Duplicate definition found for service 'Server Service' on host 'dsv-ex2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 373)
Warning: Duplicate definition found for service 'Task Scheduler' on host 'dsv-ex4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 383)
Warning: Duplicate definition found for service 'Task Scheduler' on host 'dsv-ex2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 383)
Warning: Duplicate definition found for service 'Windows Event Log' on host 'dsv-ex4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 393)
Warning: Duplicate definition found for service 'Windows Event Log' on host 'dsv-ex2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 393)
Warning: Duplicate definition found for service 'Terminal Services' on host 'dsv-ex4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 1182)
Warning: Duplicate definition found for service 'Terminal Services' on host 'dsv-ex2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 1182)
Warning: Duplicate definition found for service 'NRPE Check_mem' on host 'DSV-Tomcat1' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 1310)
Warning: Duplicate definition found for service 'Memory Usage NRPE' on host 'ds-nt34' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 1446)
Warning: Duplicate definition found for service 'Memory Usage NRPE' on host 'dsv-ws7' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 1446)
Warning: Duplicate definition found for service 'Memory Usage NRPE' on host 'ds-sql1' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 1446)
Warning: Duplicate definition found for service 'Memory Usage NRPE' on host 'dsv-vmm' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 1446)
Warning: Duplicate definition found for service 'Memory Usage NRPE' on host 'ds-msvs4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 1446)
Warning: Duplicate definition found for service 'Memory Usage NRPE' on host 'dsv-mars2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 1446)
Warning: Duplicate definition found for service 'Memory Page Usage NRPE' on host 'dsv-ad1' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 1457)
Warning: Duplicate definition found for service 'Memory Page Usage NRPE' on host 'dsv-ad2' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 1457)
Warning: Duplicate definition found for service 'Memory Page Usage NRPE' on host 'dsv-ad4' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 1457)
Warning: Duplicate definition found for service 'Memory Page Usage NRPE' on host 'ds-sql1' (config file '/usr/local/nagios/Default_collector/advanced_services.cfg', starting on line 1457)
Checking services...
        Checked 2781 services.
Checking hosts...
Warning: Host 'AmericanRailcar' has no services associated with it!
Warning: Host 'Aspire Phone System' has no services associated with it!
Warning: Host 'BBFrucon' has no services associated with it!
Warning: Host 'Centene' has no services associated with it!
Warning: Host 'Christy' has no services associated with it!
Warning: Host 'Citrix' has no services associated with it!
Warning: Host 'Contico' has no services associated with it!
Warning: Host 'Fox' has no services associated with it!
Warning: Host 'Huttig' has no services associated with it!
Warning: Host 'Insituform' has no services associated with it!
Warning: Host 'JFE' has no services associated with it!
Warning: Host 'Kellwood' has no services associated with it!
Warning: Host 'LoadMaster1' has no services associated with it!
Warning: Host 'LoadMaster2' has no services associated with it!
Warning: Host 'Marcone' has no services associated with it!
Warning: Host 'NT32' has no services associated with it!
Warning: Host 'NT37' has no services associated with it!
Warning: Host 'RC1' has no services associated with it!
Warning: Host 'RightFax' has no services associated with it!
Warning: Host 'SHRM' has no services associated with it!
Warning: Host 'UltraStor RS1614' has no services associated with it!
Warning: Host 'WhiteRodgers' has no services associated with it!
Warning: Host 'clientemail' has no services associated with it!
Warning: Host 'ftp1sslftp' has no services associated with it!
Warning: Host 'hyperv' has no services associated with it!
Warning: Host 'nt4ftp' has no services associated with it!
Warning: Host 'sftp' has no services associated with it!
        Checked 206 hosts.
Checking host groups...
        Checked 57 host groups.
Checking service groups...
        Checked 1 service groups.
Checking contacts...
        Checked 25 contacts.
Checking contact groups...
        Checked 10 contact groups.
Checking service escalations...
Checking service dependencies...
        Checked 0 service dependencies.
Checking host escalations...
        Checked 46 host escalations.
Checking host dependencies...
        Checked 0 host dependencies.
Checking commands...
        Checked 60 commands.
Checking time periods...
        Checked 7 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 27
Total Errors:   0
Post by slansing »
Okay, so you had no errors, that means there is nothing "showstoppingly wrong" with your configurations, though there are a number of errors, mostly that you have duplicate definitions, you can look at that output and figure out where they are, then rename them or remove them to clean things up a bit.
sheetzdw
Post by sheetzdw »
I don't see the duplicate entries...
see attached...
services.cfg
(347.29 KiB) Downloaded 363 times
abrist
Red Shirt
Post by abrist »
Well, they could be inherited through hostgroups or servicegroups. Can you zip up your configs and pm them to one of us?
