quick upgrade questions
Re: quick upgrade questions
I am confused, that is what I posted earlier... what are you wanting me to post?
The nagios.cfg is what you just linked, it is not in the directory I listed, we are looking for the host/service config files, when you look at your nagios.cfg you will see the lines I mentioned, they lead to the directory you just posted, you have no .cfg files at all in the objects directory? You should, at minimum, and need to have, at minimum, a localhost.cfg file for your local nagios server. The config files are going to be somewhere in /usr/local/nagios/etc and the directories further down it's tree, unless you did some strange install method that placed them somewhere obscure. You can always:sheetzdw wrote:I do not see a nagios.cfg in /usr/local/nagios/etc/objects
the other cfg files dont seem to have what we are looking for
is it possibly in another directory?
yum install mlocate
updatedb
locate localhost.cfg
