Just curious and on whim, what are your server details? I'm curious if it's a VM hardware thing.BanditBBS wrote:Update: as of 9am CST I have been at double digit load for 25 minutes and counting. I'm going to kill the nagios process and le tit sit for a few minutes just so I can use the server.
CPU Load Spike daily
Re: CPU Load Spike daily
...yeah, I have a suspicion you're right...abrist wrote:I have a suspicion that commit will get reverted . . . .BanditBBS wrote: So in short, the new scheduling is not good at all*except for the load easing).
That commit applies a random adjustment to certain checks. It obviously needs to be more constrained, and probably not random...
I'm looking into the static scheduling algorithm Core runs on startup when not using the retained schedule. We probably need to run a full, proper reschedule more often, which is simpler than it sounds. Checks with different/longer intervals, retries, dependent checks, host/service additions/removals, time changes, etc., make things 'interesting'. Efficiently generating a smooth schedule that doesn't bunch checks at some point is pretty much impossible without violating the check_interval somewhat. However, the steady state should be much smoother for simpler schedules.abrist wrote:More on this soon as Eric[1]'s work progresses. . . .
So yeah, back to the code.
Hello everyone,
I've read through this post but I want to be sure what I'm seeing on my system is the same issue we're discussing in this thread... Please see the attachment which shows the load average of the Nagios server over about 24hrs.
I did nothing differently but did notice the change in load pattern shortly after an update. While there were upticks in usage, the spikes were smaller and closer together. For the time being I've just been throwing CPUs at it. Currently I'm at 16 vCPUs at 6GB RAM.
Your symptoms do seem to line up well with what we are seeing elsewhere.
Thanks. Please let me know how I can help by submitting logs or configuration information. While troubleshooting another issue (turned out to be related to colons in service names) I de-provisioned my RAMDisk and noticed the load spikes went from about 12-15 to ~20ish.tmcdonald wrote:Your symptoms do seem to line up well with what we are seeing elsewhere.
I am going to test if it is a VM host issue hopefully later today. Getting another host configured now! I saw this at my house testing 2014 and I moved the server to a new VM host and the issue never appeared again. The weird thing is, both hosts were identical HP DL360G5 with 64GB ram and 2 quad core XEON.belvdr wrote:Just curious and on whim, what are your server details? I'm curious if it's a VM hardware thing.BanditBBS wrote:Update: as of 9am CST I have been at double digit load for 25 minutes and counting. I'm going to kill the nagios process and le tit sit for a few minutes just so I can use the server.
The server at work we are running on is:
Dell M605, ESXi 5.x, 64 GB, two 6 core AMD 2.40Ghz
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Are your virtual hardware and tools up to date?BanditBBS wrote:I am going to test if it is a VM host issue hopefully later today. Getting another host configured now! I saw this at my house testing 2014 and I moved the server to a new VM host and the issue never appeared again. The weird thing is, both hosts were identical HP DL360G5 with 64GB ram and 2 quad core XEON.belvdr wrote:Just curious and on whim, what are your server details? I'm curious if it's a VM hardware thing.BanditBBS wrote:Update: as of 9am CST I have been at double digit load for 25 minutes and counting. I'm going to kill the nagios process and le tit sit for a few minutes just so I can use the server.
We're on Hyper-V 2012. My VM specs are:
4 vCPU
12 GB RAM
Working on getting myself access to Vcenter so I can look at this myself.belvdr wrote:Are your virtual hardware and tools up to date?
4 vCPU
12 GB RAM
Great! If I can be of any help, let me know. Here's the VMware KB on virtual hardware versions for various products:BanditBBS wrote:Working on getting myself access to Vcenter so I can look at this myself.
http://kb.vmware.com/selfservice/micros ... Id=1003746
I haven't experienced any issue by upgrading virtual hardware and tools before, so it's a fairly safe option. Be sure to update tools first, then hardware.
Were you able to find anything interesting in the VM hardware?
