NagEventLog license
tgfde
Re: NagEventLog license
Post by tgfde »
I was but removed it and still the same issue.
Thanks.
Let's get a copy of your profile. In the XI web interface, go to Admin -> System Profile and click the blue "Download Profile" button. Then send that profile.zip in a private message to myself.
Tech Note: Profile received and placed in directory.
tgfde
Post by tgfde »
Hi tmcdonald,
Any update based on the profile I sent to you.
Thanks.
abrist
Red Shirt
Post by abrist »
Can we see what command is being run on the windows side? (there should be a line in the nsclient log)
I have a suspicion that the filter is not getting used at all - the command may be truncated.
tgfde
Post by tgfde »
I'm not seeing a command in the nsclient.log
Thanks.
tgfde
Post by tgfde »
This is the only thing I'm seeing in the log, which is not related to my current issue, I think.
2014-08-18 09:22:46: error:modules\CheckSystem\PDHCollector.cpp:215: Failed to query performance counters: \Processor(_total)\% Processor Time: PdhGetFormattedCounterValue failed: A counter with a negative denominator value was detected. (800007D6)
Post by slansing »
Does running the command manually from the CLI still show an OK state? Also, what is the name of the host you are running this check against?
tgfde
Post by tgfde »
Yes, corpbuild1.
Thanks.
Since the command seems to have changed a few times, can you please provide the following?
  • The command as it is defined in the Nagios server
  • The command as it is defined on the Windows server
  • A copy of your nsclient logfile
Feel free to PM the log if it contains sensitive info.
Tech Note: Log received and placed in directory
tgfde
Post by tgfde »
Nagios:
$USER1$/check_nrpe -H $HOSTADDRESS$ -c CheckEventLog -a file=$ARG1$ MaxWarn=$ARG2$ MaxCrit=$ARG3$ "filter=generated gt $ARG4$ AND source = '$ARG5$' AND id IN ('$ARG6$')" truncate=800 unique descriptions "syntax=%severity%: %source%: %id%: %message% (%count%)"
Windows:
alias_event_log_old=CheckEventLog file=application file=system filter=new filter=out MaxWarn=1 MaxCrit=1 filter-generated=>2d filter-severity==success filter-severity==informational truncate=800 unique descriptions  "syntax=%severity%: %source%: %message% (%count%)"
alias_event_log_new=CheckEventLog file=application file=system MaxWarn=1 MaxCrit=1 "filter=generated gt -2d AND severity NOT IN ('success', 'informational')" truncate=800 unique descriptions "syntax=%severity%: %source%: %message% (%count%)"
alias_event_log=alias_event_log_new
