Monitoring Engine Process failing to start
sreinhardt
-fno-stack-protector
Re: Monitoring Engine Process failing to start
Post by sreinhardt »
1 minute, is about normal if you happen to restart just before the cron that checks for those files, and then it has to wait and check again once daemons are started at the next cron interval ~1min. Did you happen to switch to 2014r1.4, thats when I noticed huge scheduling changes, and it should be mostly flat now.
BanditBBS
Post by BanditBBS »
sreinhardt wrote:1 minute, is about normal if you happen to restart just before the cron that checks for those files, and then it has to wait and check again once daemons are started at the next cron interval ~1min. Did you happen to switch to 2014r1.4, thats when I noticed huge scheduling changes, and it should be mostly flat now.
Yeah, sorry, thought that would be assumed :) 2014r1.4 all all is well with performance now for 36 hours.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
